The Multimedia system is very poor for MENA
wafa
Ouafae
morocco
macan 4
Hi,
I recently acquired Macan 4, I have many issues with PCM. The Porsche center in my region said it is related to MENA region software issues and they are working on an update with no visibility !:
1- CarPlay connects only by cable . In BMW and even BYD in the same region , CarPlay works wirelessly!
2- when CarPlay is on , Siri doesn’t work
3- when I disconnect the cable , the phone doesn’t connect to the car any more and I have to do the initial set up every time !
4- voice pilot is not functioning !
5- the assistance to changing directions. Is not on the car though it was in the serial equipments !
it is not fun to drive it under these conditions and I really really regret my purchase . I was expecting a company like Porsche to test every aspect of the car within all the regional constraints before putting their product on the market …
very poor experience . I don’t recommend Macan 4 for MENA region since multimedia basics aren’t functioning correctly
Electric Macan EV The Multimedia system is very poor for MENA IMG_5080
Hi,
Wireless CarPlay is supported. Consult Owner's manual.
Sounds like you haven't been set up fully / correctly with all the services.
I had a 4S all weekend. Logged in with My Porsche ID that I use for my Taycan and everything worked just fine (I don't use Apple).
Electric Macan EV The Multimedia system is very poor for MENA Screenshot_20250210_163530_Chrome Beta
It should work, it has nothing to do with the region. You don’t have it set correctly.
wafa
Ouafae
morocco
macan 4
Unfortunately , it has all to do with region. The car is not connected to a cellular network, which is a policy of the MENA region. The local center said , the multimedia software made for this region is specific to their constraints.
Porsche is working on the upgrade for MENA region with absolutely no visibility. They haven’t even respond with an email to my written complain …
Besides, the same Region constraints apply on BMW and BYD, but still their multimedia system is perfect .
That is said , for the missing functionality , I haven’t receive any excuses from local Porsche Center, not even an appointment with their boss to explain the matter … poor quality and poor customer care ?
This is the same situation with the Taycan since 2020 where certain functionality within Porsche Connect did not work / were not available.
If true then history shows that there won't be a solution.
siglo
Kuwait
2025 Macan Turbo
Hi,
I am located in Kuwait and I have the same situation. I’ve traded my Taycan for a 2025 Macan Turbo and though it would have a better infotainment experience. It is actually much worse. With the Taycan at least porsche voice control worked, I can connect to a wifi network, no issues with siri and I used a usb dongle to enable wireless carplay. All these things are not working with the macan. I also have a bmw, an a couple of GM cars with all functionality and connected services working.
I’ve tried 3 different wireless carplay usb dongles on the macan without luck. They all work in my other cars. I think porsche is ignoring our region on purpose, there’s no excuse when all other manufacturers have enabled connectivity services.
The difference in the infotainment system between the taycan and the macan is that the latter is Andriod “automotive” based. I thought that would be a big improvement but for our region it is clearly not.
From my experience with the Taycan most likely nothing will change. If you get any information back from your dealer please update this thread. Thanks.
wafa
Ouafae
morocco
macan 4
No visibility what so ever , Porsche seems to ignore complaints from MENA region !
I honestly don’t understand why CarPlay should work with cable in our Region and not all over the world ! If it was a restriction of the Region, it should apply for other brands as well . It is not the case for BMW nor for BYD for example.
siglo
Kuwait
2025 Macan Turbo
I also have a BMW and even through the connect services work in Kuwait, the store doesn't. So I registered my vehicle on the Thiland store and managed to purchase additional features like remote start, etc.
I tired doing the same for my manan and I managed to download the US porsche connect app and add my Macan EV to it. No functions are available except the owners manual section. In the US porsche connect store is says that my vehicle is not supported.
Electric Macan EV The Multimedia system is very poor for MENA 1742439169273-e3
I also managed to find a USB dongle that works with the macan and enables wireless carplay. However, the GPS signal and speed of the maps is not great. This is the one that worked for my Macan EV if you are interested.
jasman8888
Jason
Mauritius
Peugeot 3008
Hi,
I have the same issue in my country as well. The PCM and navigation don't work, so the voice control feature doesn't seem to work either. As for Android Auto, it can only be used via a wired connection. If you want to use it wirelessly, you need to buy an Android Auto wireless dongle thingy from Amazon, as recommended by the official Porsche dealership in my country.
I recently test-drove the BMW iX3 in my country, and all of these similar features worked perfectly fine.
Both wireless Android Auto and CarPlay are standard since launch but I suspect the feature set has been disabled for certain countries for whatever contractual or legislative reason.
Check your Owner's Manual to see what might be listed.
I suspect the services could be activated with the appropriate tooling where permitted.
ICE Macan can be software patched to support Android Auto wireless where CarPlay wireless is the default. There's a company online which provides the software to patch the PCM. Perhaps in time this will be made available for the Macan EV (region specific).
Electric Macan EV The Multimedia system is very poor for MENA Screenshot_20260712_071920_Chrome Beta
