[UK} Data Pass not activated - but it did work fine.
wuls123
macan EV
I picked up my 4S on Friday, went through all the enrolment with the OPC. Data pass was activated and worked fine until Saturday afternoon. I never lost the app connectivity as others did but only the data pass functionality.
Vodafone - 2nd line support - say it's still activated.
Porsche Smart Mobility - says it's activated
But the car now says it is not. If I toggle the 'temporary disable' in MyPorsche then the Data Pass screen in the car tells me the data pass is deactivated and I should activate it. When I toggle it back on, it has a slightly different message with the data is not activated and here's the QR code.
The QR code doesn't do anything - it is goes to part of a Porsche Website - has a Please Wait with a big spinning circle - which never stops spinning.
I've tried 30 second reset, have tried PCM reset too. Neither works. I am showing 4G with the coloured dots underneath.
So somehow, some way Vodafone and Porsche have lost sync with each other and whereas there is an activated subscription, the car doesn't recognise this anymore - and neither Vodafone or Porsche seem able to sort it out.
Bit of a disaster given it's such a key component of the car having online access!
Anyone with any suggestions - driving me mad on what is otherwise a great car.
justan
Bruno
france
macan 4s
Good morning,
While waiting for the problem to be solved you can use our phone in connection sharing.
wuls123
macan EV
yup that’s what I am doing. Not ideal and very odd that the data pass did work (albeit briefly) and then stopped working
ukdriver
UKDriver
Sounds like a dealer visit I guess.
And if you reset the PCM check that you didn’t lose the online manual in the car PCM too.
taycanstuff
Ice Grey 4S
Good morning,
Hi,
Having connection issues too with data pass, do you mean if I have my phone connected using carplay that the car will use my phone data to connect to services?
If so does using the phone data instead of the data pass mean that I should have access to all functions of the car or will I be missing some functionality compared to the data pass?
Cheers.
wuls123
macan EV
No, you have to use the hotspot function on your (iPhone) and then connect from the car using Settings > WIfi to that phone.
This assumes you are talking about the PCM’s own apps that you want to use.
taycanstuff
Ice Grey 4S
Thanks, I'll give it a try.
So I'll be using my own phones data instead of the data pass, so hopefully means all functions should still work if I'm in range of the car.
wuls123
macan EV
Anyone get this resolved? My OPC says Germany aware and working on the data pass issue for UK owners but no fix date.
is this a fob off?
wuls123
macan EV
Resolves by OPC. Dealership removed my car from app, restarted whole car authentication and login and it worked within 12 hours. The suspicion is original sign up was the weekend that everything went down Porsche back end wise back at beginning of January when people couldn’t use the app to talk to the car and somehow it all relates to that.
Anyway all resolved.
petejigsaw
Peter
Plymouth, UK
Macan 4, BMW 1 Series, Ford Ranger Limited
I had the same happen last week. Collected my Macan 4 from my UK dealer. Data pass shows up in the vehicle, but the App Center reports no connectivity.
I spoke to Porsche Connect in the UK, who were as much use as a chocolate teapot! Spoke to Vodafone, who said the connection needed to be reset, so they removed my car from my IITC account and gave me connection instructions.
They don't work, so now I have a car with a Data Pass, that can't use it, because Vodafone IITC don't have the car associated to my account.......
The dealer hasn't got anyhere with Porsche Connect either, and have no Porsche Pro available until next week. Seriously the Porsche tech is light years behind far more budget brands..........
wuls123
macan EV
well the way it worked for me in the end was the Porsche tech basically disassociated the account, made me do a hard reset in the car and essentially set it all up again.
agree on the support and tech - awful.
