Brand new Turbo: Multiple issues
MacanEV_PV
Portola Valley
Macan EV, Turbo BMWi5
Curious if anyone else had the following:
1) Apple play caused system to crash while driving - after two weeks Porsche identified a hardware problem and fixed it
2) Loose steering, sometimes. Sometimes it feels like the gas version, tight, solid. Sometimes it feels super loose. Changing mode (sport, sport plus etc doesn't solve the issues)
3) Front Screen display gets stuck. E.g. if a call comes in and the screen shows"accept, reject" the button doesn't work on the steering wheel, only the center screen. Then the "accept reject" screen gets stuck even after a restart of the car.
4) The lane assist feels really, really aggressive. Kind of ruins the driving experience.
rmwrip
Rick
Madison, WI USA
I’ve had my turbo for a couple of months. No real electronic or steering issues. Lane assist does seem a bit aggressive but I’m used to it and find it helpful given my aged reflexes.
I haven't seen any of these issues so far, but its only been 600 miles.
The lane assist can be a little annoying if not used under the conditions it is best at and sometimes puts up too much of a fight. But the button at the end of the cruise control stalk quickly turns it off and on. I'm starting to learn when to use it and when not to expect much from it and disable it.
themacnut
Jeff
Boise, Idaho
Cayenne S, 911 Targa 4S
In settings, you have sensitive settings you can adjust. Play around with it and see if it feels better. I adjusted mine to low interference and the driving experience is improved.
Nikon
Nikon
Athens, Greece
Macan
I have similar issues with PCM giving randomly some warnings like losing the speed limit signs or the infotainment sticking (no radio/music, navi not working etc) and do not come back after reset (pressing down the central knob). It is only coming back to normal operation after switching off the car for a while which is really annoying.
I noticed that when connecting the car play, the system crashes after a while.
I have an appointment with the dealer on Friday
Alex74
Alex
Macan Turbo, 356,911, …
Yes
no
yes
yes
MacanEV_PV
Portola Valley
Thanks so much. Super helpful. Will try and keep fingers crossed.
MacanEV_PV
Portola Valley
FYI, my issue was hardware not software. In case that’s helpful for diagnostics. My dealer had never seen this before and so there was a lot of factory resetting, and software testing and waiting for Atlanta to talk to Germany etc… hopefully my pain equals your gain and you get turn around faster than two weeks! Good luck!!
RickDCMD
washington DC
4S 4 weeks, the only warning “doors don’t lock automatically“ appears randomly
MacanEV_PV
Portola Valley
Thank you. And that impacted the lane assist too? By changing the rest to low?
