Actual charging time almost 2X longer vs predicted.
We’ll that’s interesting. That should be physically impossible since the macan has a 100kw/h battery and the maximum kWh you can charge at a 150kw charger in 26 is 64,95. kWh.
Does it mean that the Porsche only uses 92.8% of its battery?
documented here:
https://www.macanevowners.com/forum...acan-turbo-ev-omg-im-happy.19810/#post-301702
but this is the key picture - starting point 10%, current when pic was taken SOC @ 80% - elapsed time 26 min
Electric Macan EV Actual charging time almost 2X longer vs predicted. IMG_5501
Hawk_Tuah
Christoph
Germany
69.xx means that it must have had a faster charging speed then 150kw. It’d require a constant speed of 161kw to achieve this
seabird
Earth
Macan 4S, Audi RS5
It's right at 150kW, actually. You are not allowing for rounding in these calculations.
"26 minutes" means anywhere between 26:00 and 26:59, and 10 to 80% means anywhere from 9.5 to 80.4%. SoC calculations can fluctuate by 1-2% as well, and the "energy delivered" amount also has losses in it going into the battery.
Nothing wrong with what Dave posted....just a lucky day when the EA stars aligned and everything worked to full potential.
I don't have omnipotent EV charging knowledge - but Macan is top-tier in terms of charging speed when everything goes as planned
on my road trip home form ATL to SJC I got more than 270 kW at a charger in Lost Hills, CA, and more recently did a 10-80% run @ 150 kW EA station in 26 minutes…
only EV I know that factually charges faster is the new Taycan MY'2025 or later - it simply stunning with top charging rates in the 320 kW zone for part of the charge curve
Macan EV at a working 800V 350 kW station can get a lot done in 30 min or less…it's more than adequate for road tripping and one of the best EV's for fast charging.
