someTimesJoe
Joseph
Tri Valley, Ca
Taycan CT 4S, Macan EV 4S
The filtering is weird. Are you able to see EA or Plug and Charge at the time with Tesla? I need to have one or the other flipped and not both if not, nothing shows.
New addition is nice though as it shows availability like the Tesla app.
refazi
Refael
San Francisco, CA
Saw the same issue with the filters after todays update, i can't tell if it's bad engineering or bad product design..
The way it acts today in this release simply doesn't makes sense!
I'm seeing that if I leave everything unselected, I see the most options. Making a selection seems to restrict what you see. With the two toggles and plug and charge off, I am seeing Tesla, EA, and ChargePoint, at least.
BTW, Tesla Superchargers are now showing in the in-car nav, also.
skshimer
Skip
Southport, NC
I set mine the same way as above or no Tesla or EA chargers appear as choices. I set the charge lowest value to 150kW. I am assuming we will still have to use the Tesla app to pay for charging.
Yes. Although the plan is to eventually be able to use Porsche Charging Services using a certificate similar to what we have with Plug & Charge at Electrify America.
skshimer
Skip
Southport, NC
Thanks. That is what I thought. So it seems like a two stage roll out, which is fine
