Charging planner experiences
Wawando
Filipe
Portugal
Taycan CT GTS, 992 4s Cab, Macan EV Turbo
Hi,
I am starting to get irritated with charging planner, can anyone help me to start loving it?
The issues are:
1) range 350km, when I plan the route it gets down by about 30%… why?
2) it does jot choose the fastest charger, it chooses a 150kw instead of a 350kw that is 60km further the trip. How can I fix this? I tried to select a top at the 350kw but nothing changed in the plan…
3) And the one that irritates me more. It planned to charge until 80% for example and when the 80% is reached, even if left connected, it stops the charging 😳😳😳I tried to increase max charge from the app but it says it is being controlled by the charging planner… So I was having a quick bite and had to go out, disconnect, stop the stupid planner, then select full charge for it to continue charging until I was ready to go…
Any help? Specially on point 3?
thanks 🙏
I don't rely on the charing planner - instead use A Better Route Planner (ABRP) and Plugshare - then while traveling I only put in the "next destination" into the PCM navigation
with my Taycan the charging stop choices offerred/planned by the PCM navigation seemed to be terrible choices…
YMMV
I will not make you love it - because it's deeply flawed and not a useful tool.
Throb
NL & UK
Audi R8 V10, Taycan GTS ST, BMW i5, MB C-Class
Hi,
The issues are:
Because it takes the topography to your destination into account. The range meter shows one of two things:
1) remaining range based on previous driving (when navigation is NOT active).
2) remaining range based on the route to your destination (when navigation is active).
When navigation is active, there will be a little arrow also displayed next to the range meter.
It's actually really clever and accurate.
Electric Macan EV Charging planner experiences Screenshot 2024-10-15 154210
2) do you have the option to charge only at Porsche Charging station network switched on?
3) I tried by myself: limit by navigation at 56% but it went to 58 without any warning and I had to disconnect the cable to stop.
