Did anyone option the air filtration system? Opinions?
slythegrin
Perth
Have it optioned and run it almost all the time irregardless of air quality outside. It's it's quite effective for smells and as others mentioned there is a discernible difference in dust levels when I forget to turn it on for a day or two. The piano black surfaces' great dust indicator!
Does anyone know if the actual filter is different (presumably better) if you get this option or is it the same filter but this is just a software option to turn the system when it gets ripe outside?
slythegrin
Perth
It uses an ioniser, so different filter and filters out PM2.5… and comes with air quality sensors inside and outside of the vehicle. There’ll be a physical control to turn it on as well right next to the climate control.
ron_b
Ron
California Central Coast, USA
2026 Macan 4 (waiting at dock), 2020 Taycan 4S
I have it optioned on my 2026 Macan 4, coming in March. As the only Hardware difference appears to be the ionizer, I don’t expect any different costs for maintenance. I had opened the Ionizer on my 2020 Taycan and required no maintenance in 5 years used virtually all the time.
Ok that helps thanks. I guess I was wondering also if the quality of the filter was better..such as a high quality HEPA
MaccyT
Maarten
Netherlands
Macan Turbo / Audi Q3 TFSIe
I Have it but you don’t have to manually enable it, right? I did not press the button once since I have the car assuming it will enable it automatically when measuring bad values?
Anyway, I also hoped it had an option to add nice refreshing smell cardirdges like in a Audi Q7 but it’s just the quality of the air.
AlanH
Alan
Marseille
Macan 4, Fiat 500e
I did. My main concern was that the system would require expensive maintenance. My SA assured me it would not. Time will tell.
In any event, the system seems to be very good. Someone mentioned in another post on this forum that it seems like their car gets dusty quickly. I have not had that experience.
I’m curious to hear about others’ thoughts and experiences with this option.
I had a similar system in my previous car, an Audi A7. I found that when I used the ionizer I would end up with a fine coat of dust all over the dash so I stopped using it. For this reason I didn’t option it on my 4
robrain
Rob
Whistler, BC, Canada
I specced it (anything to help in fire season, sorry, summer). No dust issue here beyond what I’ve had with previous cars. /anecdata
