Macan EV a bit small for our dog?
sarends
Steve
BMW M3, Mercedes EQS
I’ve test driven a couple Macan EVs which I found engaging to drive and I also like the styling/ look. One thing that might make it not work is the smallish area behind the 2nd row being too small for our 80lb Briard. We have other larger vehicles that fit her more easily but the Macan would be my wife’s car and she wants to take her to the groomer or vet with needing to use my f150.
as a 2nd choice, It seems the SQ6 e-tron has a larger area behind the 2nd row, any opinions why the e-tron might or might not be a good 2nd choice behind the Macan EV?
ChrisFromUK
I did a test drive in the Q6 and was very impressed. It does have a little more room in the boot which would suit our two dogs (Cocker Spaniel and Border Collie) very well.
But then I had a test drive of the Porsche Macan found I was doomed to buy one - it really is that much better and for only quite a lot more money. Everything you see and touch and the whole driving experience is streets ahead. The dogs fit fine, a little less sitting up space but still loads of lying down space.
So my advice is don't test drive the Porsche, its too good. Just buy the Audi, have happy dogs and live life not knowing how good the Porsche is.
Or get the Porsche, dogs fold quite well!!!!!!
CHP
Christian
London UK
ex Macan 4S's
Depends on your dog's behaviour in the car, but think she be perfectly fine in terms of size. You can bring back seats in a more upright position if needed. I assume you don't use dog cage. Don't forget to oder luggage compartment partition net, otherwise you have a copilot.
ChrisFromUK
Aside from folding the back seats flat, you can also put them into a vertical (instead of the reclined) position that would give your dog a bit more space.
Actually I'd forgotten about that, It keeps the base of the boot the same size but increases the space quite a bit at dog head height when doggie sits up. Must give it a go on mine as I almost never have people in the back.
JohnnyRoaster
Outside Boston
I test drove a Q6 Prestige. I chose the Macan and missed out on a few bells and whistles. Way more fun to drive. And the Audi has had a ton of software issues.
USMA81
Phoenix
Macan 4, Macan 4
I came from an ICE Cayenne to the Macan EV, and space for my 80 lb. Golden Retriever was a primary concern, but it has worked out fine. She’s good on even longer trips, let alone trips around town. Headroom is a bit tight, but she lies down on most trips. As others mentioned, setting the rear seats more upright yields a bit more room.
Was87911
I went on a 3 hour road trip with my 75lb mutt. I folded the rear seats flat and tossed his bed behind the front seats and he was content to curl up for most of the trip. There was enough headroom for him to stand up and look around a few times.
Bruyne
Lucas
My dog sits on the back seats, of course with a dog blanket. She seems to like it much more than in the boot. It’s a German pointer, rather big.
jwatte
US, CA
I think this depends more on the dog than on the car. As said above -- the half-way-up position of the rear seats can help with boot space, but also, my wife always takes the dog in the back seat rather than the trunk of her even-bigger SUV (Volvo XC90) because that's what works for our dog.
USMA81
Phoenix
Macan 4, Macan 4
Electric Macan EV Macan EV a bit small for our dog? IMG_0163
Looks tighter than it is because of the goofy mat I have installed and because she is sitting. Standing, she is shorter and headroom is more acceptable that it looks here. I would prefer more space, but this works, even on longer drives.
ron_b
Ron
California Central Coast, USA
2026 Macan 4 (in customs), 2020 Taycan 4S
The Cayenne EV should be coming to US in 2026. Better room there and the base is only about $20k more and of the specs are so much better. 350mi Expected EPA and 400kW charging. That all being said I have an order in for a 2026 Macan 4. 😉
Jonny McCann
Jonny
Cheshire, UK
Macan 4 Electric
Our two 55 lb (each) labradoodles travel quite comfortably in the trunk area behind the back seat.
We always lower the level of the trunk (having adaptive air suspension) so the pooches have an easier time leaping-in.
notabene
Benny
Stuttgart
Our 72-lb golden retriever regularly travels in the trunk area. There is plenty of space for him. For longer trips, we have him in his dog bed, and he can still stand up and put his head on the backrest to be pet. We travelled from the south of Germany to the Côte d’Azur (650mi) in summer like this, without any issues. For short trips, we even had the small part of the backrest in cargo position (one passenger on the back seats then) and one suitcase fixed next to him.
My daughter prefers that her shepard mix ride the back seat, easier for him to get in and out and she thinks safer (large dog, I think about a lean 80 pounds). I have a 4Knines hammock style seat/door cover that works well when I need to pick him up or deliver him. There is room for his "travel bag" in the back. I also have a SUV liner, but he prefers the back seat 🙂
