- First Name
- David
- Jan 28, 2019
- Santa Cruz
- Macan Turbo,Cayenne Hybrid, 911(s) GT3/Convertable
most EV motors are AC - I'd love to hear more - so from an EE perspective 3.3v regulator will keep the each cell at 3.3 volts for "discharge_ but how to compensate when the cell drops below 3.3 v for discharge…Sorry, a good part of this is just not true at all. I have an EE background. While the basic math here is sound, if you want to adjust power output you can easily do this via voltage regulation.
In your simple single cell example, we commonly slap 3.3v regulators in front of lithium cells to run low power electronics, which keeps the voltage and power usage consistent and as expected across nearly the full range of the battery capacity.
We sometimes use buck or boost converters to adjust voltage to where a load needs it to be. There are many ways to manipulate power delivery, we don’t need to naively follow a simple discharge curve.
I don’t know much about the specifics around EV power. I’d assume though that there is some power conditioning and conversion going on to tailor the power to the load. I’m not even sure EV motors are DC, they’re always talking about silicon carbide inverters.
