The actual offroad ground clearance?
nulled
Portugal
I noticed when I put it in offroad I have another button shown on the dash where I can raise the car even further. No word about that in the manual. Is that extra or the actual/expected clearance mentioned in the dimensions of car on their website... (Me being lazy and not wanting to go to the garage and measure it)
tonyadduci
tony
chicago, il
porsche macan gts
is the "lifted" height or when you put the chassis in the lift status the same height off the ground as "offroad?" I am noticing the ground clearance is lower than that of the 2023 gts.
that's crazy....a little dent like that was an issue?
LivingTheDream
Thomas
Greater Boston
2022 718 Boxster
This article might provide the answer you're looking for. Here's the relevant quote...
In off-road driving mode... High Level I is activated, increasing the ride height by 20 mm. A lift of 40 mm is achieved in High Level II
yes - hence my reluctance to "offload" the Macan - Porsche has been "radio silent" when asking about Macan's battery tray vs. dents vs. off-road…I escalated to PCNA to discuss if 3 mm dents are more/less/same as an issue with Macan - and so far no response.
I would simply suggest you take an "informed" approach with regards to Macan+EV+offroad+battery-tray-dents+3mm potentially being a costly repair…
all Macan owners are of course welcome to do what they wish with their vehicle - but I'm not sure as to the differences between Taycan/Macan from a battery tray cooling channels design and their tolerance for minor dents/abrasions/normal-wear-tear…
