Wallbox Pulsar Plus - not liking Macan 4
sloubere
Stephane
Chicago
Macan 4S IG
For NA, the latest firmware version for Pulsar Plus is 6.6.15, released 9/25/24.
Pulsar Plus NA – Software version 6.6.15 OCPP Improvements: Fixed an issue where the charger could lose the OCPP connection…
There was also a release in Dec 2023 addressing a similar issue:
Rel 6.1.12
  • Fixed a bug that could cause the charger to go to error when plugging it to some car models.
I have a Pulsar Plus Wallbox and will be getting my Macan next month, interested to know whether this is a Wallbox hardware issue or just old firmware that needed updating.
snb7x
Bertie
Northern Ireland
Taycan 4S, Taycan Turbo & now G2 Taycan 4S plus Macan 4 due 11th Oct
My Firmware was updated when this problem originated … no improvement to allow timed charging schedules so only “direct” plug in possible and hence less scope to charge at low overnight rates unless I want to get outta bed 12.30/01.00am to plug the Wallbox Pulsar plus to Macan ?
robpoo90
Robert
United Kingdom
Macan 4 EV, Defender PHEV, Maserati MC20
Same issue my side. On the same wallbox firmware version (5.17.87) and can’t get the handshake between Macan and Wallbox Pulsar Plus (22kw) so that scheduled charging operates with Octopus Inteligent Go tariff. Annoying! Has worked fine on all my other EVs. Have raised it with Wallbox support and await useful feedback.
snb7x
Bertie
Northern Ireland
Wish you luck … my approach to Wallbox 3mth ago ended in “nought’ … they offered a special price to buy a replacement after 7-10 days of experiments, updates, resets, etc.
We now manually set up direct charge around 22.30/23.00 any evening the Macan needs charge and switch the car to direct charging before plugging in … ?
robpoo90
Robert
United Kingdom
That’s pants and not a practical solution for me. I’d be shocked if they are not working on a fix for it. Unless they see it as an opportunity to force new hardware purchases which would be pretty low.
snb7x
Bertie
Northern Ireland
interestingly my installer advice was “be careful with following their advice as your Wallbox will be out of warranty” … I’m not suggesting there’s anything malicious with their support more a case of a throwaway commodity product approach when they get a bit puzzled!
Meanwhile my Taycan charges on timed overnight low tariff profiles via the same charger without issue. ?‍♂
Sparky
Joe
Norfolk, VA, USA
2025 Macan S EV
I have a Wall Box Plus, purchased in Autumn 2021. It worked correctly with other electrical cars I have had. I have not tried a delayed charge procedure as it makes no difference to my power provider when I plugged in with respect to costs. However, once the charge is complete, my wall box throws a red ring light (error code 306). After I unplug it, it is green and ready to go without a reset. My software version is 6.1.12.
Looks like it is technically obsolete.
