Warning symbols on dash for first 5-10mins
JonnyDW
Jonathan
Hampshire, UK
Last two times I’ve set off in the car (only had it a week) (both times were early and quite cold/damp) I’ve had various warning amber warning symbols on the dash. They then go away after 5-10 mins of driving. Seems like it‘s a sensor issue but has anyone else seen this?
Thx
This is just life with this car, update to WSJ0, ignore and enjoy driving ;)
JonnyDW
JonnyDW
Jonathan
Hampshire, UK
It’s true it does’t change my life! Is WSJ0 the latest sofware update? I assume mine has it since i picked up less than a week ago.
Thx
Moisture / dew on the windshield where the camera is located and / or on rear and front sensors could be the reason.
Collision Warning, Speed Limit Detection and Lane Departure are the 3 icons which should normally light up at start up as they're checked and then extinguished after a period of time. Prolonged time could be due to heavy moisture or road spray rather than an issue.
Left hand (collision detection) icon normal at start up, usually goes away after three or four minutes. Disappointing to see the other rotating icons on a 2026, but you say they also go away after a few minutes of driving. Do you also get any warning messages on the right hand tube? If not, I wonder if this is normal for a 2026?
JonnyDW
JonnyDW
Jonathan
Hampshire, UK
No, there are no warning messages. Just the icons. I don’t think it can be considered “normal” it’s ok for too long, but very likely to dew in the morning … though goodness knows how it’ll perform in the rain if this is dew.
On my MY24, on the rare occasion that I do get those icons, I also get a yellow warning message in the right hand tube, and there's also an exclamation point icon to the right of where your display is showing the lowered car level icon. The ! Is persistent as long as the icons are also showing. In my car, I would say the icons have shown up less than a half dozen times in the 18 months I've owned the car without explanation, and a couple of times with an obvious explanation (i.e. very heavy rain).
castlg
Gary
Westhampton
2025 Macan EV 4S
I frequently use a Tesla Y and A Rivian. Both have the same inclement weather issues with the sensors
I've also seen these warning status icons that seem to be left over from a previous drive. They clear after a few miles, if no longer active. I only see the right tube warning message and Icon for something new. Pressing the revert button clears it, but does not clear the smaller status icons. Those reset a period of time after the condition clears.
Compromises to the camera lenses and camera view (sun) seems to be the most common conditions that sets these warnings. Other sensors are more tolerant.
