What is the optional 19.2kW charger Porsche talks about?
I think this is an excellent point, especially for the longer run as the batteries become more affordable or even as EV batteries are recycled into static applications. Reasonably affordable comprehensive storage systems, maybe associated with rooftop solar panel technology with the power consumption going both into the home and the vehicle sounds like a reasonable view of the near future.
Not sure whether it is cost effective yet. In my area and taking into account the federal incentives (soon to go away) it costs about $30k to install a solar system with a power-wall storage. You only save about $14 a month on your electricity bill and break even in about 20 years. Maybe worth it if you just moved into your house with young children so you are expected to stay there for a long time. Otherwise, you are just financing the next owner. I’m not planning to leave and hopefully will live that amount of time… but my wife is always talking about downsizing or following the kids when they settle, specially if grandkids decide to “show up” lol
Hopefully at some point the technology is more affordable (likely) and the politicians figure it out (impossible dream).​
SteveInKirkland
Stephen
2024 Porsche Macan 4 EV
Not sure whether it is cost effective yet. In my area and taking into account the federal incentives (soon to go away) it costs about $30k to install a solar system with a power-wall storage. You only save about $14 a month and break even in about 20 years. Maybe worth it if you just moved into your house with young children so you are expected to stay there for a long time. Otherwise, you are just financing the next owner. I’m not planning to leave and hopefully will live that amount of time… but my wife is always talking about downsizing or following the kids when they settle, specially if grandkids decide to “show up” lol
The people who are really benefiting from solar in the USA live in the "country"/suburbs and build the ground arrays themselves from 100 USD "leftover" 500 watt panels and then use less expensive Chinese battery tech than Tesla sells. If you're a heavy energy consumer, payback can be pretty quick (like a few years). But my wealthy friends are just buying solar+batteries as a comfort hedge against utility outages.
But I suspect current-day (early 2025) battery cost limitations are the bigger concern. I assume both solar cell and battery technology will continuously improve and cost less per kW and kWH over the relatively near term (5 years?) I think @SteveInKirkland's point with 100kWH to 300kWH batteries would enable fast DC charging (say 10-80) of a 100kWH EV battery, while recharging the fixed battery from AC (or solar) at a lower rate (he mentions 100 amps, but I think depending on the use case, 48 amps AC would be sufficient). My thought is, if you have a battery that big, might as well use it as power backup or time-shifting for the domicile also.
Edit: (completing the thought) So, iow, rather than spend the money to upgrade the OBC, just bypass it and spend the money to charge using DC at an even faster rate (which would then work for any future EV as well).
SteveInKirkland
Stephen
Oh, yes. You completely received my point. Not only would I be extremely hesitant to spend $20k to get 19.2kW AC charging on 1 car, but I the latest research that I've read suggests that slow charging at less than 9.3kW increases battery pack longitivtiy. So, most of the time, I likely should go slow charging.
There will always be use cases for faster AC charging. My brother would probably pay for it. He refuses to charge his Rivian R1S any where but his homes. He commutes between the beach and his city home about 3 hours. He just doesn't want to sit and wait at a charger outside of his home.
JohnnyRoaster
Outside Boston
Maybe I haven’t had enough coffee yet this morning, but am I missing something about this discussion? I can’t think of a scenario where I wouldn’t have time to charge at home overnight. I don’t see the need to double the charging speed at home. It’s not like either of my homes would be in route to another destination for a fast charge.
ChrisFromUK
It depends on how much you are driving.
Here in the UK I have cheap rate overnight charging costing around ÂŁ0.01 / mile of driving but I only get that rate for 6 hours so I can charge for 110-140 miles / night (depending on times of year/temperature) at that rate.
If I was regularly doing more than that many miles then I'd either need to charge at an 8 times more expensive electricity rate or charge faster. I could upgrade my current 7KW charger to 11KW which would give me around 170-220 miles per night but if I wanted even more then I'd need both a faster charger and a car than can take the higher power - like my wife's Renault can.
As it is, our daily use is well below these levels and I have advance knowledge of longer journeys and so can charge up over a couple of nights.
TS23
BMW G82 M4
Just as an FYI incase yu aren't aware, but upgrading to 11kw is actually an infratstructure challenge, not a charger issue. It might be the charger is capped at 7kw, but swapping it out will not resolve the issue.
i have 2 EV's and it would free up the charger faster to charge the other.
two Tesla Universal Wall chargers configured in "powersharing" mode will share the same single Electrical circuit and charge 2 EV's at the same time splitting the load - max power from each of these units is 48 amps (60 amp breaker) - you can configure upto to 6 of them to share > 200 amps - when mulitple EV's are charging they dynamically share the load - so has not to exceed the max power you configure/allocate - it's way more effective than a single 19.2 kW EVSE
I've done this for _YEARS_ with both the Gen2 and now the Gen3 Universal chargers - I'm currently rocking 3 Tesla Universal Wall Chargers each configured for 60 amp breaker (48 amp max charge rate) and they are configured/told they have 80 amps (100 amp breaker) total power to "share" between themselves…
plug in upto 3 EVs/Hybrids and then let the system sort itself overnight while all 3 cars charge at the same time…
I _ROUTINELY_ charge my: 2021 Cayenne Hybrid, 2024 Macan TurboEV, and 2022 Tesla Model Y (previously my 2020 Taycan Turbo) and other Hybrids and EV's when friends/familiy are visiting…
for a multi-EV household a loadsharing/powersharing/split-load EVSE setup is 100% the way to go.
ChrisFromUK
My house has 3 phase electric supply so I can install a 22KW charger if I wanted. If I did then Porsche would charge at 11KW and my wife's car would take the whole 22KW.
