Window goes down by itself
PaoloPix
Paolo
Audi A4 Avant - Macan 4
I would like to report a problem that happened to me 2 times
After lowering and raising the window until it closed, it automatically went back down to about half open.
I tried to raise it several times but each time it went back down. I discovered that if I gave an additional push as soon as the window reached the maximum point I was able to block it but if I got out of the car at the moment I closed the door it went back down.
In the end I got out of the passenger door to be able to leave the window up. The app still reported the window not closed.
It happened to me again and this time after several attempts I solved it by completely lowering the window and raising it again. Has it happened to anyone else?
HltMacan
Har
Netherlands
Yes, it happened to me two times now. First time I had to mess around a few times with the button up, down down up before it closed (rear window, driver side). The second time the passenger window was apparently not fully closed, and had to close it fully, which worked immediately. Elsewhere in this forum someone had a workaround, when window closes half and when closed opens half again. I have not tested it yet, but the workaround was : push and hold down the button, then shortly push down the button again. Same sequence but then up.
JohnG
Chester-le-Street
It happened to me, only the once thank goodness, and I got round it by lowering the window completely and then closing it
I’m getting a bit concerned at the number of faults in the electrics on these cars, and it seems that they affect many cars, not just one.
This also happened to me, and I discovered the procedure for resetting the window auto functionality. For some reason it becomes uncalibrated, and you need to recalibrate it. The steps are as follows.
1. use the window button to inch the window fully open then. Do not pull it to automatically close. Wait 10 seconds
2. Use the window button to inch it to the fully closed. As above do not pull the button all the way or you will invoke automatic closing. Wait 10 seconds
3. Repeat 1 an 2
4 then it should be calibrated at the full open and close now
5. Try automatic opening now and it should work
The dealer walked me through this on the phone and it worked
3. Repeat 1 an 2
I cannot remember how many times I had to repeat it. it was at least twice but it could have been 3 complete cycles. I will try and call sevice to see if I am missing any steps. I would suggest 3 cycles just to be sure
thealbs
Manchester, UK
Macan 4S Slate Grey Neo
I have had the same issue 4 times now. Alarmingly I tend to discover the window has dropped when I return to it after some time away. I have ‘re-trained’ the window on what closed should look like on every occasion but it continues to misbehave on the one window (passenger front).
I called my dealer who could not fit me in for several weeks but they suggested I call Porsche Assistance. In the UK this is subcontracted to the AA. They arrived at my house within 1 hour of the call (impressive), spent a while talking to their remote Porsche expert, but said they could not resolve the issue and referred me back to the dealer. I am back at square one and do not trust the car to remain secure when I leave it in public right now.
There is a separate thread on here for the same issues too. It seems this is not uncommon at present.
https://www.macanevowners.com/forum/threads/nearside-left-front-window-opening-itself.18907/
prime
Having this problem as well recently.
Albatros
Mercedes GLC AMG 43
Had the issue. Ordinary reset (like here described) helps but not for long. Had to go to the dealer to make new configuration with their computer. It took 1 hour - seems it works now...
thealbs
Manchester, UK
Thanks. let's hope my dealership can do the same. Still saying it will be March before they can fit in in though !
PaoloPix
PaoloPix
Paolo
On Sunday I found the left side window halfway down in a shopping center parking lot. Very dangerous. After 2 attempts with the limit switch memory procedure I managed to close it.
Last night when I got into the car the left rear window went down by itself. When I tried to raise it it would go all the way up and then go back down halfway by itself. Only after 4 attempts to reset the limit switches was I able to close it.
Trevasann
Trevas
Las Cruces, NM 88011
Porsche Macan 4EV
Hello, yes, it has happened to me among numerous other software/electrical issues. I'm beyond concerned and will be a frequent flyer at the dealer. I"m now keeping a detailed log, as there are many quirks as the dealer calls it. I'm in the desert and I have no A/C. Got my car late December 2024
The only A/C issue that I have seen in this forum was one owner had received the car without refrigerant done properly. Even though there’s may be refrigerant if it was not done correctly there will be issues. Mentioning in case that has not been checked in your case yet.
thealbs
Manchester, UK
just had the same work (I think) done on my car. Reported updates in full in separate thread
Did yours stay fixed??
Albatros
Mercedes GLC AMG 43
yes. after the dealership new reset; it has not happened since than.
