Piano black climate control: how will you protect it?
The piano black climate control seems very prone to scratch. How can we protect it?
Electric Macan EV Piano black climate control: how will you protect it? IMG_5833
Got Porsche film for climate controls area and central display. I've already put on the climate controls area: It is not as precise as I would like but it does the job. Now I have to install the one for the center display (and remove the factory protection I still have).
Part number should be: 9J1 044 000 71
I think it could work but, if you have a detailer to make the curved part wrapped, he could also made you the protection film for the screen
Argelius
Argelius
Southern California
Macan 4 EV
Following this thread. Designers for car interiors should be fined for putting piano black on anything.
Flxjet
Brussels
992s
Hi Diego, i bought the same protection set,
Is that easy to install? or would you recommend some technician to do it?
Thank you
Thank you
At the moment I installed only the climate control protection film. I have to find the time to install the center display protection but it’s easy and you can do it on your own
ferrocinque
Francesco
Roma, Italy
Thank you Diego. Where did you get the films? From your local Porsche dealer?
Thanks
gregb
2025 Macan EV 4S
Could someone post a picture of what the the final result looks like after installing the console protection? Thanks!
thank you, will give it a try
:like:
I’ve installed it on the main/passenger display, you have to stop the fan, remove the dust with the tape, check for all the dust and use the provided scotch to hold the screen protection during the process. Do it under direct sunlight.
The result is nice (from left to right side)
Electric Macan EV Piano black climate control: how will you protect it? IMG_6303
Electric Macan EV Piano black climate control: how will you protect it? IMG_6305
Electric Macan EV Piano black climate control: how will you protect it? IMG_6304
Looks nice but highly reflective. Was hoping for a Matte or anti glare finish
