Avoiding login when starting?
Félix
Cádiz (Spain)
Hi all, does someone know how to avoid having to log in when starting the Macan? Thx in advance
I believe you might have the glitch when the car setup didn't work perfectly the first time, usually due to a spotty connection. Is it asking you to login every time you start the car and other small glitches?
A factory reset will fix this. I forget which screen exactly, but somewhere in settings you can do a "Factory Reset". It takes about 5-10 minutes to do the reset & setup. You will lose any saved settings.
Great_Cookie
Malaysia
Alternatively, if you're talking about having to enter a PIN code every time you start vehicle then it could just be that you have to disable "Access Protection" to "No Access Protection".
Electric Macan EV Avoiding login when starting? 1736437999405-s1
Screenshot Credit from YT Video here (3min 54sec): Comprehensive Porsche Macan Electric Set Up
jim101
Texas
M3, RR Sport, F-Pace S
Is it possible to change this setting once the initial set up is complete? Our dealer missed this when we took delivery, and I can’t find a way to change it in the existing menus. It’s annoying to have to input the PIN each time we drive the car.
I’m hoping a factory reset isn’t necessary. It’d be a pain since we’ve had the vehicle for months.
TIA.
CHP
Christian
London UK
ex Macan 4S's
TIA.
Yes it's possible, did it myself as I was in the same situation like you. Can't recall where it was exactly. Sure others here are happy to help out.
