Macan Turbo EV - home made spare wheel kit?
Is that the typical Porshe jack point or will I need to find another adapter for my floor jack?
BTW, these diagrams are in the manual:
Electric Macan EV Macan Turbo EV - home made spare wheel kit? Screen Shot 2025-01-04 at 8.34.33 AM
Electric Macan EV Macan Turbo EV - home made spare wheel kit? Screen Shot 2025-01-04 at 8.34.57 AM
nischalr
Ft. Lauderdale, FL USA
Right…. I finally got it - and you’re right - it’s a rectangular jack head…and no damage to my car by the tyre man.
And under the car there’s some sort of metal sheet protecting everything - the composite material is just around the edges!
Thanks for the pictures!
nischalr
It is not the same as the Taycan for sure. It looks like the same as our recently totaled Q8 etron. The pad I used on the etron linked below. I will confirm it when we get the Macan in the next week or so.
https://a.co/d/2Q07Tge
ukdriver
ukdriver
UKDriver
I ordered this puck from eBay. If this fits I’ll be ordering a jack :)
Electric Macan EV Macan Turbo EV - home made spare wheel kit? IMG_1388
ukdriver
ukdriver
UKDriver
Right…. From the user manual… seems the car comes with a jack!!! - I’ll check tomorrow!!!
Electric Macan EV Macan Turbo EV - home made spare wheel kit? IMG_0528
ukdriver
ukdriver
UKDriver
Definitely no jack in my car. Weird the manual has the guidance above.
ukdriver
ukdriver
UKDriver
This arrived today and it’s too short and does not fit the car. So tomorrow I will measure the right diameter needed but I’m guessing it’s about 10cms and needs to protrude taller too.
Electric Macan EV Macan Turbo EV - home made spare wheel kit? IMG_0536
Electric Macan EV Macan Turbo EV - home made spare wheel kit? IMG_0535
ukdriver
ukdriver
UKDriver
Right - I’m at the Porsche centre at Reading - and just found a solution.
Who knew Porsche had a collapsible spare tyre + wheel for the Macan Electric!!!! News to me. I didn’t even know these existed - they save space (max 50 mph).
You have to inflate the tyre before use, and deflate it before storing away. Living and learning. Hopefully it will be small enough for the frunk.
the code P95C601027 ensures it matches the holes when you pull out the original tyre / wheel for the Macan electric.
It’s on back order in the UK - so when it arrives I’ll post pictures.
Electric Macan EV Macan Turbo EV - home made spare wheel kit? IMG_0624
centrovi
Carlos
Puerto Rico
2025 Macan 4S, 2012 997 Turbo S coupe, 991 4S coupe
Please post if it fits well for 22 rim.
Thanks
damn, sorry to raise this one from the grave...but i was just about to start working on the car.... and others have noticed, despite the manual saying there is one, there is no jack in the car....
The other Macan pads don't seem to be right... I do see images of the Cayanne Jack pads, and they seem to be more in line with the macan shape...
anyone find the right pads yet?
nischalr
These look like they would fit, but I had these for my Audi Q8 which is MLB Evo, and tried it on the Macan and it does not work, it starts angling off kilter. The jack point is bigger and open on one side requiring what I suspect is a very specific adapter that I have not found. Luckily a carefully placed hockey puck like pad that spans the jack point without touching any battery components worked well enough.
still on the hunt for the specific PPE platform adapter
Damn... Well i already ordered. I was too impatient. Maybe this requires a trip to the dealer
RGBArgee
Rick
Somerset and Brittany
This is great info thank you so much - I hadn’t considered that a back wheel would not fit the front wheel arch. now it’s obvious! Thank you! From what you are saying I think buying a front wheel & a capable jack would probably resolve my issue.
I already have a spare front tyre (Continental - which is tyre that the tyre man sourced overnight and replaced the original damaged Goodyear).
I ended up buying another Goodyear (I didn’t want different tyres on a brand new car) and kept the sourced Continental when Porsche replaced it.
I guess I now need…
1) a jack capable of lifting a 2.4 ton car
2) a Porsche 22 in wheel….
unless someone has a cheaper solution….
thank you
Porsche Assistance? I agree a spare would be nice but not filling up my boot with one!
it fits the backset perfectly, but does not fill the space on the front...i'm not sure it needs honestly. i find it peculiar that the specific pads wouldn't be available to buy from Porsche
