kWh usage per month history / records?
Lybaek
Bo
Denmark
Macan Turbo EV
Is there a place (in the Porsche App or in my Macan Turbo) where I can see an overview of the kWh usage per month?
Yes!
Can't you export the data from Charging History and review in PDF (or convert to Excel) - top right hand corner - fliter / download?
You can also apply filters (start to end month) within 'Charging History'.
Ensure you have the latest version of the app.
Electric Macan EV kWh usage per month history / records? Screenshot_20250114_154644
Electric Macan EV kWh usage per month history / records? Screenshot_20250114_154705
Lybaek
Bo
Denmark
Macan Turbo EV
Thank you very much for your advise.
Are you using the Porsche App on an iPhone?
In my Android version I do not see the download symbol and the charging history in the same way. I will dig further .....
Android but the update came a few months back when this first appeared so check you app is up to date.
I think that it only works with a Porsche charger (I can see the export function neither…)
Could be (I have the PMCC) but I've always thought that it was cloud stored with your My Porsche ID and so accessible independent of the EVSE - annoying if not. The source may be the issue and if not the car then that might explain it.
I keep asking this from day zero of ownership. On this aspect Tesla wins again and again...
Which EVSE do you use?
If not Porsche then I assume your brand will have the data accessible somehow or other.
PMC+ (also Porsche) is not WiFi enabled so I'm guessing many owners won't have access to charging history either if not accessible separately in the cloud.
I use a GEWISS Wall Box that has only bluetooth connection and doesn't have any kind of report... Tesla app was amazing on this aspect: detailed charge information and trip data... Maybe Porsche, with two EVs, will think about something like this. I'm not a software engineer but I think it's something doable.
