Wireless charger
nerv
Huy
BMW M3
I’ve never had an issue charging my iPhone 15 Pro Max in the Macan’s wireless compartment with the Spigen Ultra Hybrid MagFit case.
https://a.co/d/hXl5Zj6
I have the same case but having some trouble charging. I tried moving the phone around but no luck so far. My wife’s phone works with her MagSafe case…not sure what brand
My Apple brand Magsafe case on an iPhone 14 works fine but it needs to be placed a bit left off center. There seems to be a sweet spot there.
masmole
I don't own a Macan yet but during my test drive of a Macan Turbo, I placed my iPhone 16P with an Apple-brand magsafe silicone case in the Macan's wireless charging compartment and it charged with no problem. My wife has a thicker non-Apple case she bought from Amazon and it would not charge without removing the case.
RickDCMD
washington DC
I’m unable to wireless charge my iPhone 14 Pro, I removed the case and still saying unable to charge, my phone charges fine and even other cars. Any suggestions? I don’t understand why is so hard from Porsche to design a simple wireless charger, my Taycan charger wasn’t that good neither but at least charged the phone.
justan
Bruno
france
macan 4s
Maybe you need to activate wireless charging in the settings.
nick776
Huntsville, AL
Macan E Turbo on Order
I have an iPhone 16 pro in an apple branded silicone case with MagSafe. I have to position mine just right to get wireless charging to activate.
jyk4212
Oz
Macan
Wondering if anyone had further luck being able to describe how you can get this to work. I have tried with and without case. Intermittent, sometimes it will start charging and about 30secs later it comes up with same error.
Electric Macan EV Wireless charger IMG_0615
Slide it a bit left and right till you find the sweet spot. Mine is left of center, camera on the left side..
Jono101
Jono
Sydney, Australia
I have the same problem in my 3 day old Macan. Sometimes by iPhone 14 charges, but has started to frequently display the same error message. I have tried with and without the Apple magsafe case, but it makes no difference. I'll try and move it around to see if that makes any difference.
I have an iPhone 17 Pro with an Apple TechWoven case with MagSafe and have no problem with wireless charging. I don’t even have to reposition the phone. I just drop it in the compartment and it works. It also worked with an Otterbox Symmetry with MagSafe.
Paris92
SFO
2025 Porsche Macan 4 EV
Mine was not wireless charging for my 15 Pro, and my wife’s 16 Pro, about 80% of the time. Since the software update I can basically throw my phone in the cubby and it wireless charges 90% of the time.
figure1a
San Diego
Taycan, Macan
I have a phone case that is mag safe and works well with my home and other wireless chargers. However it doesn’t work on my Macan wireless charger. Anyone else encountered this issue? If so, what case do you recommend I buy? Appreciate your help.
This works way better. For whatever reason, the Porsche built-in chargers are always garbage—both location wise and functionally.
Electric Macan EV Wireless charger Screenshot 2026-04-18 at 09.35.59
I’ve had most success by putting my phone in with the top towards the left. This seems to line up with the charging system better. My 15 Pro is shorter than more recent Pros and the Pro Max versions
I’m sad that the only way to see it’s charging is on the Car Play screen, where the battery status is displayed at the top of the sidebar
How does that handle aggressive driving, will the magnets hold a big phone with its case through ~1G maneuvers or on bumpy sections of the road? I would think you'd want the phone physically restrained.
I sometimes have passengers that need a cable connection to charge their phone, and I don't have a spare USB port for this. Wonder if a Y cable would supply enough power to both.
I suppose you get enough cooling there but probably not as good as in the cubby.
BTW, once I learned the sweet spot, I have not had a problem charging my iPhone,
