Proper tire inflation
maddie288
Nate
Ohio
2025 Macan Turbo EV, 2021 Boxster GTS, 2024 Range Rover
I have a 2025 Turbo with all Michelin Pilot All Season 21" tires. The tire pressure plate on the door says 45/psi Front and Rear. However, in My Porsche app it shows at 45, the tires are over inflated by +2psi each. I know there is a partial load setting in the menu, but that didn't seem to make a difference. Any thoughts?
sloubere
Stephane
Macan 4S IG
I believe the pressure on the door sticker is for full load. You can view the partial load recommended pressure in the user manual.
RunningOnSolar
Scott
Ohio
Macan 4, Subaru Solterra
Mine show 44 +3 psi each with exception of front left at 42 +3 psi. Apparently this indicates the amount over the recommended pressure. I would only worry if the pressures were considerably more out of tolerance and/or you were stressing the car such as heavy towing or using it on the track.
Pressures also tend to vary somewhat based on temperature. i don’t know if you’re in north, central or southern Ohio, but there has been quite a variation in temperature, at least in the southern part recently
Doggo
Doggo
NYC
Turbo
Use the pcm to tell you exactly what it should be. It takes amb temp into account. +- should be 0.
Barry41561
Barry
Los Angeles
2025 Macan EV 4S
Thanks for this...
So, I'm now rather confused: I've always used the doorjam for proper pressure (for my 20' Summer tires it indicates 41 psi).
The Porsche app shows that the tire pressure should be 35 psi!
Am I truly to rely on the Porsche app?
RunningOnSolar
Scott
Ohio
I asked the question of my dealer service and they told me they tend to slightly overfill tires to avoid tire pressure warnings, hence the +3 in my case. However, do what makes you most comfortable and consider the amount of temperature variation you exp to deal with
Doggo
Doggo
NYC
Turbo
Thanks for this...
The manual also tells you, but will tell you it's for a static 22c or similar (forget exactly). Door jam doesn't have an amb temp
