TPS now in bar v psi
maddie288
Nate
Ohio
2025 Macan Turbo EV, 2021 Boxster GTS, 2024 Range Rover
Today I noticed my tire pressure monitor is reading in bars vs psi. It changed on its own it seems. I do not see an option under tire monitoring in the PCM to switch the measures. Do you know how to get psi to display again?
rjf
Randall
United States
2024 Macan 4
My display switches back-and-forth randomly between PSI and bar, for no apparent reason. ??‍♂
yeah, this happens randomly.... i think it happens after charging for me randomly.
Mine changed from psi to bar. I know this sounds crazy, but I think I changed it in the App - Account / App Settings / Units / Tyres / psi and that changed it in the car as well. If it is the Ap, then that some way explains it happening after a charge which was set by the App ?
AndrewH
Andrew
Australia
Tesla Model S
There is a way to change units of measurement in vehicle settings somewhere. Unfortunately I can’t remember where the menu is as the menu structure is so convoluted. You can also change 24h time to 12h which is another setting I was keen to change
System, units - same place whee you set 12H or 24H and consumption units.
Consult the Owner's Manual.
AndrewH
Andrew
Australia
Tesla Model S
I could well be wrong but like many things, I’m not sure that this is actually described in the Owner’s Manual. And yes, I have read it and also tried searching for this particular setting.
I still think it can be changed in the App and then that changes in the car.
