Owner’s Manual Update Available
strwbryfruitcake
Thank you!
unrelated, does anyone else think the current owners manual/good to know (digital or physical manual) is not in-depth enough for how many functions our PCM has? I feel like our PCM deserves its own manual espc with the HUD and acc/innodrive
Thank you!
It is a little light yes. I would also like it to cover more car & maintenance than it currently does (both digital and paper versions).
For instance, didn’t see anything about replacing the pollen filter, nor the reference of the filter to get. But there’s a (short) blurb about brake fluid…
Bertone
Norway
Porsche Macan 4, Volvo 780
Maybe currently for English language only? My Norwegian Owner's Manual is still v1.0.3 - no pending update notice for now.
It’s entirely possible that the manuals are both country and model specific — in fact I would hope so, to account for the differences in equipment. For all I know you could get different content based on the options you spec’d, like the HUD, InnoDrive and type of charging doors.
Does anyone else with a 2025 Turbo see this version?
I think so. I recalled on another thread different terminologies used for example
“Overrun recuperation” vs “thrust recuperation” depending on location
There is an entire section on Care and Maintenance
https://manual.porsche.com/#/wpi/XAB-2025-20240826-43-RDW-4.0.3/en_GB/main
Electric Macan EV Owner’s Manual Update Available Screenshot_20250503_080057_Chrome Beta
The cabin air filter, also known as the pollen filter, in a Porsche Macan (including the EV) is typically located behind the glove compartment on the passenger side of the vehicle. To access it, you'll need to remove a small rubber cover or panel under the glove box, revealing the filter housing.
stevieg
Steve
v1.0.3 in the UK
Electric Macan EV Owner’s Manual Update Available Screenshot 2025-05-03 at 11.43.51 AM
MFitz
Michigan
Macan 4S PS88FTV9
Was there always a chapter on Online Software Update? Don't remember seeing this. Is this the PCM OTA updates we always dream about or did I miss this from the earlier version?
Yep there is, I mentioned it in my message as I read the whole thing and found it lacks substance.
Not a word about the filter whereas they do talk about brake fluids. As a basic owner, I’d change the filter before I worry about changing brake fluids. ;)
Thanks for the details re: glove box, I’ll take a look!
The filter will be replaced as part of each service cycle so no real need to go there IMHO (they'll still charge you for the service).
