Rear Wiper Replacement
Briboynyc
Brian
Dallas
Macan
I am trying to get a rear wiper replacement blade (it actually fell off as it was wiping...so that's not cool). Wasnt a fan of the original OEM blades and wanted to get Bosch blades but on their website they list two different versions that is compatible with the macan. First model is A381H and the rear of the box says compatible with Macan 95B 03.14 -> which I am assuming is from March 2014 to current. BUT I believe the Macan 95B is the gas version. Bosch also lists part number A383H as being compatible but I dont even see macan listed on the read of the box just VW and Skoda.
Anyone have any idea of a replacement blade that is not OEM that will fit? Which Bosch model? RainX? other brands?
Robertok
Robert
Louisville
Mazda Miata. Genesis GV60.
Rear wiper? Do you have the same car I have?
Robertok
Robert
Louisville
I was told that it was not an option, that it was eliminated for aerodynamic reasons. In any event, I have never found it to be needed.
[...]it was eliminated for aerodynamic reasons.
True. However, a rear wiper is still available as an option unless you specify the acoustic and thermal insulated glass. If you bought your car off the lot you may not have been aware of that and gone solely by what the sales guy told you, but if you look in the online configurator, you will see it.
there's really no reason to get a XAB specific wiper...just look up the size of it. Almost all of the wipers comes with all the needed adapters /etc to fit all cars...
get the brand/style you like
Briboynyc
Brian
Dallas
Macan
I got Bosch which they said would fit on their website but it didn’t
What didn't fit? There was no adapter for the attachment?
ch2576
Washington
I had the exact same issue, the rear wiper felt off while driving, probably after using a car wash.
The Macan 4 rear wiper is a new model, with a new connector, and several brands that claim to fit do not. The one that worked for me was the trico rainguard 55-150, but it was hard to make it click, and it looked flimsy.
It felt again on its own 2 months later. I ended up going to Porsche, and they replaced it with an OEM one.
Interestingly, they had a hard time fitting the OEM one, as it had to make *two* clicks. So it made me think that 1) you need to put quite a bit of pressure to install it properly, and 2) it probably had not been installed properly at the factory in the first place.
Scotsman58
Weston, CT
2024 Porsche Macan 4 (leased); Subaru Crosstrek Hybrid; Toyota Prius
I just received replacement Bosch wiper blades for my 2024 Macan 4. I wish I had seen this thread first. The new front blades (Bosch Icons) went on easily and seem like a big improvement over the OEM blades that came with the car. The rear blade I got -- a Bosch A 381H -- does not fit, although the Bosch website said it would. Quite annoying. Is there any option other than the Bosch OEM rear wiper?
Briboynyc
Brian
Dallas
Macan
I could not find any non-OEM replacement blades that fit the rear. What model Bosch did you use for the front because I desperately want to change them
Scotsman58
Weston, CT
Bosch 24" Icon ClearMax 365, Part # 24OE & Bosch 20" Icon ClearMax 365, Part #20OE. Use the #4 adapters that come with them.
Bennie
Ben
Eindhoven, The Netherlands
Macan 4, MINI Cooper S
An earlier search for the rear whiper showed me the Bosch A332H. I searched again for being a matching part, but I can’t confirm it.
A search on Bosch Netherlands shows A281H.
Confusing what the right partsnumber is…
petejigsaw
Peter
Plymouth, UK
Macan 4, BMW 1 Series, Ford Ranger Limited
I can confirm having replaced my rear wiper blade today (it like others fell off......) that the Bosch A360H is a perfect OEM fit.
:like:
Briboynyc
Brian
Dallas
Macan
THAT IS GREAT NEWS that there is a different wiper blade that fits. Its sad that the OEM blades fall off and its interesting to hear other owners having the same issue
