- First Name
- peter
- Dec 23, 2024
- Austria
- Macan Turbo EV, porsche 911 limited edition, GMC Sierra Grande1971, Smart Brabus
you should consider to read the manual:I don't have to convince you...if I set a fast charging station as my destination and my battery is cold, I can travel slowly or quickly, the battery is heated to reach the optimal temperature,...if I remove the destination, my battery doesn't heat up as much as before and obviously the available range is greater...
„Battery conservation function
When the battery conservation function is activated, an overall charging limit of 80% is set for the high-voltage battery. To utilize the vehicle's full range, the charging limit for individual charging processes can be increased to 100% if necessary.
If the battery reaches an excessively high temperature due to external influences, the battery is conditioned (cooled). Depending on the parking time and the battery charge, the temperature range for conditioning is reduced.
Activating the additional battery conservation function lowers the temperature threshold for conditioning depending on the parking time. This reduces the charge level more significantly during longer parking times and at a battery temperature above 20 °C, which has a positive effect on the battery's service life.„
but belive what you want. it is just annoying to read complaints about stuff that does not exist..
