GTS delayed
Adrian B
Macan E GTS delivery April 2026
Same here, pushed from end of July to mid-August. No notification, just new dates showing in the app.
I was due to get my gts in early May now the app says early July although dealer think maybe June (wishful thinking)
Count me too with many above, e.g., my ordered car arriving with chosen air suspension or order would be cancelled.
Reactions: MMR
Camelman
Range Rover Sport, Mini Countryman S
Same if tbis happened to me i would be cancelling my order
Well that is a question of mine. Last Porsche I had was before kids, no air suspension then! First time for getting an EV too, and it's on a BCH through my company so I'm not keeping it past 3 years. With that in mind is the air suspension a must have over PASM?
racerjim
Jim
Canonsburg, PA
2024 Mercedes Benz GLC300
me too. I guess I better hope my air suspension doesn't fail on me....
aks
Tony
Hertfordshire, UK
BMW F90 M5, BMW F48 X1
You should go and make a test drive with the wheels/suspension you will likely order/get - that's what I did. We found that air suspension w/22" spider wheels smooths out the bumps/pot holes on UK roads nicely. At that point, I didn't try a car without air, as the dealer didn't have one readily available.
Camelman
I have spoken to the dealer to do just that. Not surprisingly they are having problems getting a 4 or 4S pool car for demo with just PASM, which already tells me what the dealer thinks! However, been told I might have to wait until September for air suspension.
Air comes with PASM as standard. PASM on its own simply stiffens or softens the shocks.
Air is key to ride comfort and has several active features that you'll miss out on - SmartLift (memorise locations of speed bumps) and active ride height.
Not essential but highly desirable.
I would not purchase any Porsche where air is an option without it.
Go test drive.
Adrian B
Go test drive.
Totally agree, can’t wait for my gts - I really like the new active ride but it’s only on the Panamera and Traycan and not cheap lol!
TS23
BMW G82 M4
That's going to be very subjective and based upon experience of Air and preference but if ignoring the height adjustments and driveability in different modes, just in ‘normal’ is leagues ahead for comfort in my opinion.
I'd almost be reluctant to have a car not the way I've ordered it. The reason I waited 8 months for a factory build is to get the car the way I wanted.
Id imagine they will be prioritising other vehicles up the spec range (so another consideration) but if its gets that bad that they have orders pulled, they will fix it quickly so it maybe able to be added back in before spec is locked.
I just checked with my dealer if there are any delays with GTS production. They have assured me that there are no delays that they are aware of, may be specifically to my build, expected to lock on Apr 30, with delivery to Baltimore port, and arrival to me in Indiana in early July. Of course, everything is subject to change without notice.
I wonder if anyone got their GTS already in the US?
Glad yours remains on track. From your comment (and probably experience with prior Porsches) you are acutely aware that schedules can change at any time. Good luck!
I read somewhere that possible supply issues pertaining to suspension components was impacting several manufacturers not least Porsche. This is due to a single source supplier whose factory had a fire - based in Europe.
