- First Name
- Andreas
- Oct 1, 2024
- NJ
- Macan Turbo EV, E-tron, M3
Wanted to see if anyone out there knows
On DC charging it is straight forward.
The closer you are when charging to 100% SoC the lesser you car will draw from the charging station. But how is it with AC charging ?
I ask to know if you actually waste AC energy when you charge your car past the 80% SoC. On DC it won’t waste as it is same current. How about AC ? Will the 40-50 amps still be drawn from the house power while the car gets less kWh charged ?
It seems there is less energy lost during DC charging while on AC it seems you loose more. Wondering if anyone knows how that behaves ? Thank you.
If there is a bigger AC energy waste by charging past the 80% would be helpful to know. I usually don’t, to prolong the Batterie life. But I think it would be helpful to know in case I needed 100% SoC.
Thank you.
Thank you.
