Software Updated - Collision Alert System Down?
dwauch
Santa Monica CA
2025 Macan EV
Hi all. I just had the software update performed. To VR28.13. I'm worried the Collision alert system could be down. And who knows about automatic braking. I had 1-2 incidents I thought should have triggered a warning. And I've tried to safely test the system - which is not all that easy.
Has anyone had this issue with the update? I read about lane keeping issues, I believe.
I wish there was a better safe way to test the system.
The ACC cruise works fine. And lane keeping seems fine. I didn't realized It only works over 40mph.
I've reached out to the dealer.
I do not believe there was any issue with collision warning prior to the update.
My 4S collision warning works fine after the update. The only issue I've noticed is that it is sometimes slow to start a Level 2 (EVSE) charge. I've been contemplating having the dealer pul the vehicle charger update out.
dwauch
dwauch
Santa Monica CA
2025 Macan EV
are you saying the dealer can reverse the update? I'd never heard that.
ironically for me, I think the update is meant to improved the collision mitigation systems, perhaps reduce false positives. But gosh - i'm pretty sure it is not working for me now. Which is disturbing. It's an important safety feature. I will look at to make sure the collision mitigation system is turned on and at max sensitivity.
There were changes in the on board charger software that causes some cars not to charge via the owner's home AC charger. Dealers can revert the on board charger software. Dunno if they would be willing to revert the entire update package.
dwauch
dwauch
Santa Monica CA
2025 Macan EV
Just went out to the car... Geez, could they make it any more incomprehensible.
1) you have to go to a buried link in the vehicle assistance systems page titled "additional settings," to find where to turn the emergency braking system on.
2) you then have to press the little gear button on that page to realize there is a sensitivity adjustment. I presume I want it on High, but nowhere, anywhere, do they explain the difference between high and low sensitivity.
3) you then, completely separately, have a three second hold of the emergency flashing lights button to turn on (or off?) the whole system.
4) There is also a warning/dashboard indicator light, that I think only comes on to indicate the system is active if you did the emergency flashing light button thing above, #3. By the way, the dashboard warning message (in the left main binnacle) that shows when you press this button is completely confusion. It makes no sense to what you just did.
5) in addition, the owners manual has about a page of conditions for the system to operate, at different speeds, of which about 10% are clear.
In my car just now, when i went to it, the system #1 was turned on and sensitivity #2 was high. But I'm not sure if #4 was showing. So I did the #3 3-second hold. I now have the warning light showing, which i'm not sure was there before. I guess I will have to try and safely test it again or go into the dealer. it seems crazy that I could have #1 and #2 on, but still have to do #3 to make it active. This is a pretty major safety system.
If I take it in, I'm afraid I'll have to make an appointment 3 weeks out to get a loaner.
Alas - I only document this in case someone else runs into a similar situation.
Thanks for listening!
dwauch
dwauch
Santa Monica CA
2025 Macan EV
Thanks. I definitely will not do it while driving. I also read that pressing the P (park) button also acts like an emergency parking brake. Not clear what the difference is then between the two functions.
Do I want to have the "
Electric Macan EV Software Updated - Collision Alert System Down? {filename}
" illuminated in my dashboard? Apparently that means "The emergency stop function is switched on and active." The only way to toggle that on/off is the flashing light button 3-second hold, I believe.
I dunno but there seems to be two features being crossed pollinated here, collision avoidance and emergency braking, but then I may also be confused.
There is emergency braking which slows the car when driver incapacitation is detected or someone presses the hazard button for 3 seconds.
Then there is brake assist for collision avoidance which can automatically apply the brakes based on exterior sensor input (acoustic parking, cameras, RADAR if equipped). Before I turned it off, this feature would stop the car as I tried to back out of the garage.
SuperH
Helen
Walsall, West Midlands
Those who have been on this forum for a while know I have done nothing but complain about the random emergency stops my car has performed for no apparent reason, all the warnings that kept popping up, the attempts to force me into oncoming traffic that the lane assist had done, and as very unfortunately evidenced last December - the shoddy safety systems in general which completely failed to identify let alone avert a collision at 25 ish mph. The collision avoidance nor the emergency braking kicked in, and the sound recording on my Dashcam doesn’t even pick up the ping from an alert notification (it all happened too quickly for me to say whether it did or didn’t by sight)
Would not surprise me one bit if you were having similar issues with any of the road monitoring system performance as Porsche themselves don’t appear to know what’s what with it.
After my bump, once the body shop had done their bit on the bumper and wing which took 9 weeks because of parts shortages with Porsche and other issues, they couldn’t get the safety systems back online properly so sent it to Porsche who did the large software update which should have fixed a lot of the general issues, and supposedly resolved the systems errors caused my the crash. They had not. So back it went to Porsche and 3 weeks of investigations and a complete change of camera array later I picked it up on Wednesday last week (a total of 12 weeks post bump!). I don’t appear to be getting all of the false warning about potential crashes now, but I’m still getting warnings to take over the driving when I try to use the Innodrive, so something clearly still isn’t right with the whole road monitoring system.
Electric Macan EV Software Updated - Collision Alert System Down? IMG_1115
dwauch
dwauch
Santa Monica CA
2025 Macan EV
I work with a lot of cars, and so many manufacturers are having issues with all these system. It's complicated. And I'm generally very happy with my car. But gosh, collision alert has been required for several years now. You'd think they'd have that important system working reliably by now.
Dekord
Slovenia
Macan 4, BMW iX1
On the highway, the driver in front of me suddenly started braking hard because of an obstacle in the road, while I was very close to him. My Macan reacted immediately and tightened the seat belts, a beep sounded, a big red collision warning light came on and the car started braking automatically. The car responded as it should.
dwauch
dwauch
Santa Monica CA
2025 Macan EV
Great to hear! The insurance institute loves these system, so they are doing their job in the big picture.
ch2576
Washington
Fyi some folks had an issue after the software update where the car thought the mirrors were folded when they weren't. That made some of the collision alert system not work, e.g. no door light warning for changing lanes.
Radar systems are pretty reliable, camera (LIDAR) not so much but are cheaper. Manufactures are trying to use software to analyze video to do things like collision avoidance and adaptive cruise but have not been that effective. Simple things like sun shining into a camera (driving into a sunset or sunrise) or a highly reflective surface will confuse them and they drop out to a safe mode (off). Its the nature of LIDAR in the real world.
Just saying that the systems could be better, but not as long as sensors more suitable for parking are being used for double duty..
Yes, folding them in and out recalibrated them.
