I wonder if this could resolve cracking sounds coming from the suspension when driving over speed bumps.Harmonized handling when driving over uneven surfaces: Adjustments in the chassis control concept ensure more comfortable and quieter driving over bumps and uneven surface
Maybe because NHTSA is specific to the USA market only they do not list changes for other markets. Have not been through the change logs to see if they have [EU] references inside, just guessing.(EU markets) Harmonization of the warning tone in the event of speeding: The audible warning has been adjusted and replaced with a more pleasant sound (was definitely in SQ4 though, maybe they just forgot to list it in the Changelog)
Ah yes, I missed the detail it was the differnces between the two. Thank you for the clarification.@Flying4Fun, well maybe it wasn't clear but what I did is taking your list and remove the entries that were listed in the .pdf for SQ4 already.
I had saw on the work order it said recall, but I didn't click in this was an actual recall - I glossed over that when reading it. If they are committed to this as a recall, that must mean they have high confidence in the repair effectives also.The SQ4 update was optional but the SQ5 is a global recall campaign WTA6.
Just booked an appointment and confirmed the content of this update is exactly like this list mentioned here before. Dealer says it should indeed reduce the issue of sounds coming from front suspension.
