keeping car a/c on while running errands for family/pets in car?
strwbryfruitcake
I have a habit of running errands with a family member with me while I run into the store real quick, but when I close the driver door the whole car turns off even with the key in the car. how do I keep pcm awake and ac on for them while driver door is closed?
Reactions: MMR
there's literally a button that shows in the screen asking you if you want to keep the car on, as soon as you put it in Park. (for me at least)
If youi're not getting that, you need to go into the setting to turn on that Prompt. i don't remember where it is...but there's definitely a setting.
as soon as you put it in park, it will ask if you want to leave the car running.
It will stay completely on for 30 minutes.
The thing to note here...is that will stay on at your next stop too......
Often I'll turn that option on at the store...and when i get home, i get out as usually...and as I'm exiting the garage, i hear the car is still on, or I come back to see the car is still on...That option will remain on till the car is turned off or the button is unchecked. so just be aware
beside the option to keep the car "on" which includes entertainment, windows and ac, there is the option in the AC menu to have the Ac on for 60 minutes. the same option you have in the app.
"pre climate"
Trevasann
Trevas
Las Cruces, NM 88011
Porsche Macan 4EV
I use it all the time, but is there a way to lock the car while it is on? Ty
There seems to be confusion here.
On the Exit screen you can click the switch to leave the car running. This warns that the car is not locked AUTOMATICALLY. You can absolutely lock the car manually when you are outside the car
The pre climate is not required for any of this. Click the switch, exit the car, lock the car from the key. Job Done!
Do note that the car is running - navigation to a charger will continue to precondition the battery for best charging speeds
joeev
Cayman, Macan EV
Also, on the goodbye screen there's a toggle to disable interior monitoring to turn off the motion sensor.
You can also turn off the motion sensor temporarily by clicking lock twice on the key fob. the second press turns it off
JohnnyRoaster
Outside Boston
I was confused because the mirrors do not fold like they do when I normally leave or manually lock the car. I checked it today and the car does lock when you manually hit the lock on the fob. The mirrors do not fold in.
strwbryfruitcake
strwbryfruitcake
thanks for everyone's response. I didn't know it was a setting I could toggle as mine doesn't have it, only have the option for interior monitoring. ill tinker with it today!!!
strwbryfruitcake
strwbryfruitcake
I found it today running errands bro thank you so much. I'm blind and stupid apparently lmao
question, i was messing around with the settings, and I couldn't find a setting to turn on the prompt, so it must come on every time by default...BUT, I noticed that it comes on when in park, and you unbuckle the seat belt....
so i was thinking, if you're not getting this prompt, are you using your seat belt?
strwbryfruitcake
strwbryfruitcake
I thoroughly embarrassed but I do use my seat belt yes
