- First Name
- Tomek
- Sep 28, 2024
- Poland
- Macan 4
Hi, I have not had any experience with air suspension before this vehicle.
Have some problems with the car pulling to the left but only at high speeds on highway.
I've had suspension alignment done and it's correct but... this is in locked/normal mode.
When you lower the car the alignment goes off (toe, camber) mostly on the right side.
Dealer says it's normal it happens but... is it though?
How can it be, I get the alignment might change a bit when the height of the air suspension changes but can it really go outside of the specification?
My printout from the alignment test in lowered mode is all red on the right front/rear wheels and dealer brushes is off. I see the car is not stable at high speeds compared to loaners I had. They don't see the problem.
