wmras
Bill
Oregon
I do :( Granted it doesn’t put out 40a, but it looks cooler, haha
It will deliver 40A and remember it once changed in settings if you upgrade the firmware to 3030. Upgraded ours via Wi-Fi at home - it has the original NEMA 6-50 wall plug.
it should do 40 amps - have you addjust the amps? what size breaker are you rocking?
Raek
New York
Macan Turbo, E92 M3, Wrangler TJ
Weird. I could’ve sworn there was a big issue with the chargers overheating with the solution being a throttle down of the amperage. Guess I never got the memo.
c’est la vie…I pick up my Macan Turbo on Friday, so plain Jane chargers it is!
nice. so this is what's included in that big bag in the trunk? and they have wall mounts, but can also quick release for travel?
Remember that you'll have to disconnect the tails - screwed in - so not quite undock and go!
No different to Taycan or any VW EV / hybrid - same stock EVSE.
macanchan
Allan
do you have to screw it in? It doesn't look like its necessary
The tails - yes on prior models as they were shipped with a choice of tails. No EVSE supplied as standard in UK from MY25 onwards. Suspect the same today. Go check.
