robrain
Rob
Whistler, BC, Canada
Wow, they have 200 amp service in a 17th-century barn to support a charger? That would be impressive.
I’ve only got 100amp in my modernish townhouse, but it supports, at a pinch, our Tesla wall box and a hot tub. We have some fancy box that makes sure the hot tub always has supply when it needs it.
My point? 100 works for home charging if you’re careful.
AlanH
Alan
Marseille
Macan 4, Fiat 500e
Not sure - maybe I did but I didn’t want to back in with the bikes. The charging cords swing both directions so they work for either space. As I recall most of the chargers there were empty. In my travels so far (in France mostly), the charging stations are amazingly empty. Typically there will be 12 300Kw chargers and only 1 or so taken. The Porsche nav shows the number of chargers available so you know the situation before arriving. Since getting the car in January I’ve never had to wait to charge.
KombuchaBioleather
Dallas, TX
'25 Lexus450h+, '25 Macan4S
Cornwall last weekend. First proper opportunity to use off-road mode 😀
What did you think about off-road mode? Every time I've turned it on, I've found it to be incredibly bouncy. I assume it's not meant for roads - really just meant to be used on slow-ish, rough trails?
pm4s
Ok after spending even more time looking at this photo and trying to figure out the layout this is what I came up with:
1) The bay you are parked is only meant for 1 (very long) vehicle, as there is no separation line and the vehicle in front would have been boxed-in by the vehicle in the rear.
2) The 2 chargers are actually facing opposite directions and you have used the charger for the bay to your left. You can see your bay extends further to accommodate the distance between the 2 chargers.
