Route settings error
lee999
lee
kitchener, canada
macan turbo,Audi TTS
Getting this every time I try to plan a route on the app. Any ideas?
Electric Macan EV Route settings error image
I was getting that, I found that the state of charge at departure was set far too low and the % at arrival was far too high. I set the departure at 100% and the arrival at 10% and it solved it.
Goldtrom
Rob
Portland , or
Macan 4, bmw m4
My soc is set correctly. And I’m only a mile from a charger. There isn’t a state of charge that would fail.
llindenb
Larry
United States
2025 Macan Electric 4S
I had this problem for a while after the app decided that I no longer had a valid charging certificate installed. I was unable to ultimately fix the problem without support from Porsche directly.
Check under the charging settings to see what it says about having a plug and charge certificate.
Had a similar “can’t get there from here” determination from ABRP the other day in error; got home just fine with 40% SOC just as the Porsche Planner predicted.
I always double check my trips with ABRP before departing. Rarely one is off. Overall he Porsche Planner has worked over 90% for us so far.
