- First Name
- Bob
- Dec 22, 2024
- Wivenhoe999
- Macan 4S
The App will give you the efficiency from charging, total to date and recent trip.
Electricity is not measured in distance, but kWh, at the scale of an EV.Mine at the moment shows 389 kms and it's getting lower and lower the longer I use the car
You are correct, I was curious because it reflects this range based on your long term average consumption. It does not predict the weather for you next trip or how fast you'll go but it gives you an estimate for your particular driving style and conditions. I would also assume it reflects the SoH of you battery as it should calculate this based on the usable kWh and not just the %SoC.Ultimately, the range estimate is just that, an estimate.
That’s why I referred to the outside temperature. In cold weather the consumption goes up > predicted range goes down.You are correct, I was curious because it reflects this range based on your long term average consumption. It does not predict the weather for you next trip or how fast you'll go but it gives you an estimate for your particular driving style and conditions. I would also assume it reflects the SoH of you battery as it should calculate this based on the usable kWh and not just the %SoC.
In my case it's spot on - i'm mostly driving on highways at constant high speed, do a lot of fast DC charging, the battery is often warm. I also noticed it's slowly but surely decreases over time which makes me wonder why.
Every EV battery will lose some capacity over time. As far as I know, every manufacturer calculates SOC percentage based on the current capacity. That's what I was referring to in my first point. So, 100% of a new Macan is ~95kWh (100% =95 kWh). Maybe after a year, the battery has lost 5kWh of capacity (5.25%). The SOC on the display will still show 100% when the battery is charged as much as it can be now. (Now, 100% = 90kWh.)... I would also assume it reflects the SoH of you battery as it should calculate this based on the usable kWh and not just the %SoC.
... I also noticed it's slowly but surely decreases over time which makes me wonder why.
I’m on my 2nd EV now (Audi e-tron the first) and have read and studied just about everything there is about EVs.Yes, I detected a decrease in range with roughly the same driving profile - temps dropped but from 30C do 15C which should reduce the need for A/C to cool down without the need for running heat.
The person you are quoting is talking about 30C temps to 15C temps. That is not nearly in the temperature range to cause a dramatic, noticeable range change.I’m on my 2nd EV now (Audi e-tron the first) and have read and studied just about everything there is about EVs.
Especially in cold climates where I live. Summer +28c winter -28c.
Batteries just don’t perform as well in cold weather. That is a fact. Every other opinion is just that, an opinion, not a fact.
The AC effect you mentioned is nothing in those temps.
I might have come to a wrong forum, as the discussions here seems to be lacking a lot of facts about EVs, that are common knowledge in Europe.
So I won’t be taking part in any more discussions, since it seems quite pointless.
Drop from +30C to +15C I mentioned is something you can consider "cold weather" and thus should not affect range.Batteries just don’t perform as well in cold weather. That is a fact. Every other opinion is just that, an opinion, not a fact.
The AC shouldn't have a big impact in the scenario I mention.The AC effect you mentioned is nothing in those temps.
I have not seen any noticeable drop in range at a constant outside temperature range and on a common route. Racked up 10K km already.Mine at the moment shows 389 kms and it's getting lower and lower the longer I use the car![]()
Funny you mention it because I always do but the car seems to prefer using it's own batter for heat. You can easily check it - charge the battery, then turn on climate control, you'll see it does not use power from the charger to do this. One of many many many things that is wrong with this car.One thing I would suggest is on cold mornings keep it plugged in. The benefit of having it plugged in (and at 80%) is when the pre-warmup kicks in, it's using grid electricity and not draining the battery. I only go 100% pre-departure on long routes.
Ha, interesting. At 80% or 100% charge? Or regardless of charge level? I'll give it a shot.Funny you mention it because I always do but the car seems to prefer using it's own batter for heat. You can easily check it - charge the battery, then turn on climate control, you'll see it does not use power from the charger to do this. One of many many many things that is wrong with this car.
