What's your estimated range with 100% SoC?
320 at 100% and it seems to be fairly constant. I do a 50 / 50 mix of local and 70mph journeys. According to the App my average consumption over 6 months has been 3.2 miles / kw = 304 theoretical which is in line with Porsche configurator which gives a consumption for the 4S of Electrical consumption combined (model range): 3.5 – 3.0 mi/kWh
FINMacan4
JJ
Finland
Mine at the moment shows 389 kms and it's getting lower and lower the longer I use the car ;)
It's getting colder in Poland, isn't it? That's why the range is now dropping. Same here in Finland, 100 SOC range down from 520km in the summer to 450km as the temperature has dropped by around 20C.
metinson
Mike
Montreal
Macan EV Turbo Macan GTs
I get about 525 km’s when the weather is above 20 C.
i get approximately 410km on highway driving like my former ice turbo (set on 150 kmh) in the city over 500
Interesting, 410km estimated with highway drivng at 150km/h?
I drive mostly on highways at 140-150km/h and the result I have on 21" is a bit lower but not by much.
Barry41561
Barry
Los Angeles
2025 Macan EV 4S
Averaging 3.5 miles /kWh over 7,000 miles.
At times, 100% can occasionally be over 350 miles.
Electric Macan EV What's your estimated range with 100% SoC? Screenshot_2025-10-02-08-13-18-50_6fb2a52ea4dd5c61fb51be0714df4a00
chaz
Charles
2025 Macan 4S, 2007 BMW 328xi
This value is based on moderate driving. I'd say I could trick it into a higher number if I went full eco for a while.
Temps in were in the 80's during this time. Battery about a month old. I have 22" Spyders.
Electric Macan EV What's your estimated range with 100% SoC? macan-100
Barry41561
Barry
Los Angeles
2025 Macan EV 4S
What's your lifetime efficiency?
Barry41561
Barry
Los Angeles
2025 Macan EV 4S
How do I find that?
On the right side of the dashboard display. When you access that area, you can scroll through various options, radio, navigation, and efficiency. When in efficiency, you can press the button on the steering wheel, and scroll up / down. The down will show you lifetime (if you haven't reset it).
chaz
Charles
Looks like 32.9kWh/100mi
