If it would be helpful, I would like to collect in this discussion records of problems described by users up to the date given in the title:
Area / thread linkIssueRegionUserCauseFix
Air Conditioningno cooling is provided.
US​
No freon installed​
Air Conditiong / ventspassenger side floor vent / flapper doesn't close
US​
TBD​
Loose connection fixed, solved
Climate Control Buttonbutton intermittently don't work when the car is powered ON
US​
TBD​
Satellite Radioconnection lost
US​
TBD​
Not a recurring issue.
Electric charger port coverpassenger port works randomly
US​
Sensor out of position​
Owner's Manual in PCMNo Contents are available in PCM
US​
TBD​
Instrument Clusterinstrument cluster does not turn on (display blank / dark)
Canada​
@dmd
TBD​
Blind Spot MonitoringBlind Spot Monitoring not working
US​
TBD​
Assistance Systems Error - Speed Limit Display (Warning Message)Intermittent fault messages displayed on instrument cluster
UK​
TBD​
Assistance Systems Error - Speed Limit Display (Warning Message)Adaptive cruise went out
US​
TBD​
Loud buzzing sound from mirror areaAfter triggering the front collision warning system there's a loud buzzing sound coming from the upper mirror area (cameras/sensors just below the mirror) getting worse pressing the plastic cover
EU​
TBD​
Car restart solved
Front (air) suspension crackingCracking sound from front (air) suspension when driving slowly over speed bumps
EU​
TBD​
DC Charging Issue Due to Software GlitchDC charge at an Electrify America terminal - no success.
US​
software glitch
Bose sound stopped workingOnly two front speakers works no matter what I do, reset pcm
EU​
TBD​
Compass intermittent functionsometimes compass works properly and sometimes it does not
US​
@dieterf
TBD​
Trunk emergency release errorVehicle sounded alarm and displayed warning message while parked in garageCanada@shawnUnknownAlarm stopped on its own after 10 minutes and trunk operation is normal
Smoke and burning smell from air ventsBurning smell and smoke from air vents when driving 130 km/h (80 mph) or higher, with or without the climate control on
EU​
@piter95
TBD​
Rotating Random Sensor AlertsSeries of rotating random alerts that keep cycling
US​
@GaryV
TBD​
Charge PortCharge port doors can open on their own in automated car washes
US/CAN​
@daveo4EV
TBD​
Charge rateIt appears North American Macan's are capped at 40 amp charge rate and not the 11 kW (48 amps).
US​
@daveo4EV
TBD​
Plug & Charge"Plug & Charge" toggle that won't work. Unable to P&C and P&C option is grayed out on PCM and APP
World​
Many
TBD​
Solved by @TomekGnomek . See instructions here
âš  Please consider this thread as a glossary thread, which links to individual reported issue threads (where everyone can reply and comment). If you have an issue, please create a new discussion thread for it and it will be added to this list.
Good open discussion. I am just releaved to know it is not an issue with the car. That is my takeaway.
macanchan
Allan
My passenger side floor vent / flapper doesn't close. Constantly blows air unless climate control is turned off. The up/down toggle on the center console wont turn the fan/system off on passenger side. I need to go through the screen menu to turn off the fan.
Climate Control button on center console does not bring up the menu on the screen intermittently when the car is powered ON. Maybe it's still loading.
@macanchan I recorded your issue. Please open a dedicated thread so I can link the problem to that thread. Admin will delete all the messages in this one to make it easier to read and to permit other users to ask/comment about your problem
when i click on the Charge port cover link, i get that i'm blocked...but the others work fine
n4v4nod
It's because I never created a new thread for that specific issue. I included it with my AC issue. I did receive a call from my service department regarding it though. They stated that they repositioned the sensor and it works as designed now. I'm on my way to pick it up now. Hats off to my dealer for quick/prompt resolve with all my issues. Once again proving great customer service.
macanchan
Allan
I think my climate control button in the center console is working fine now. as long as you're not in camera mode, it will display.
