Delete model designation on side blades?
nick776
Huntsville, AL
Macan E Turbo on Order
I've searched but cannot find an answer. Some people's photos on here show the model designation on the side blades (Turbo, 4S, etc.) but others do not. Is there an option to delete the model designation?
It’s an add on option. Found on ā€œExterior Decals and Logosā€.
nick776
Huntsville, AL
That answers my question--by default it is "deleted" as with other models you have to select "delete model designation." There is no way to delete the model designation at all on the rear though it seems.
i think this varies by country/region... and we've certainly got a mix in here
US configurator does not show an option to delete model designation on the rear that is common for other models. However, removing model designation is easy, so I would not worry about it.
Frankie
Netherlands
Porsche Macan
In the Netherlands we can check off the logo for the back. See photo. The "Electric" logo is not present as standard and you have to check separately if you want it.
Electric Macan EV Delete model designation on side blades? Clip_8
SuperH
Helen
Walsall, West Midlands
in the UK there is the option to delete model designation on the rear, and by default it isn’t on the side blades - either the model or the word ā€˜electric’
nick776
Huntsville, AL
I want the "electric" logo deleted.
rmwrip
Rick
Madison, WI USA
I’ll be asking my detailer to remove the electric logo. They may do this anyway in order to apply ppf.
alvaro
Ɓlvaro
ATL, GA Metro - USA
I got PPF and they didn't remove the electric logo.
But it's body colored so you can't really see it.
The PPF shop usually uses a heat gun to remove the logos and then applies a continuous sheet of film and then uses adhesive to reapply the logo so there is no cut lines around the logo. I don’t even know how they would do it otherwise. That is how my shop did it.
alvaro
Ɓlvaro
ATL, GA Metro - USA
That makes sense.
