Macan 4 EV - Octopus intelligent sync issue
stevieg
Steve
Have you found it to be reliable Steve? Its my first run of it tonight but had a few issues when I let the EV Charger schedule previously.
Any issues with the car coming up with a charging error when it is first plugged-in if Octopus doesn't permit it to draw charge?
Also, I am assuming this is all controlled by some central Octopus server-side cleverness once configured, and it doesn't rely on the App being active on your mobile?
Cheers
Ok so you need to make sure you have completed the test charge so the Octopus App knows when your car is at home and that it has control of the MyPorsche app. It will stop the charge by creating a departure schedule in the charging section of the Porsche App and thus making the car suspend the charge. Octopus then uses this to turn the charge on and off.
The thing to do is to plug the charger in when you are at home and leave it plugged in as much as you can. The car WILL start to charge initially, as your charger will be set to start charge straight away. Within 30 minutes, but normally less than 5, the Octopus App will suspend the charge and show you a schedule in the app. Just leave the car plugged in and by whatever time and SOC you have set in the Octopus app, the car will be done.
I always make sure my target charge % is the same in both the car/Porsche App and also Octopus.
App just needs to be on your phone and logged in I think (to get the notifications). You don't need to be actively 'in the app' for it to work.
See how it goes!
thealbs
Manchester, UK
Macan 4S Slate Grey Neo
See how it goes!
Thanks for the advice.
I wondered where that random Departure time entry had come from in the Porsche App but this explains that also!
stevieg
Steve
Yeah, got me too! It will keep updating every day to be around a week in advance. If you do charge elsewhere, you might need to turn it off or use 'Direct Charging' whatever that is!
It's so the Octopus app can test that it can control your car and schedule the charges as the correct time. Normally you only get 6 hours of 7p per KWh but with the App controlling it you can get AS MUCH POWER AS YOU NEED at 7p to get the car to up to 100% by the time you set on your Octopus app. It's a great way to get much more than 6 hours of cheap electric by just scheduling with your charger app.
So the test charge is essential for the Octopus App to know that it can communicate successfully.
I use Ovo Charge Anytime for the same 7p rate but no requirement for testing. Checks are made by the software before you sign up to the service.
SimonEV
Simon
United Kingdom
I will try the wait for the white light technique.
SimonEV
Simon
United Kingdom
Direct Charging just means ignore any request mechanism that inhibits charging and start “now”.
SimonEV
Simon
United Kingdom
As well as starting the Octopus Test Charge when the car’s white light is active and connecting/negotiating:
Move the Charge Limit down in the car e.g., to 50% so that charging is stopped. Start the Octopus Test Charge. increase the Charge Limit up in the car e.g., to 80% so that charging is no longer inhibited. Octopus Test Charge completes and the Octopus Service is activated.
thealbs
Manchester, UK
1. Move the Charge Limit down in the car e.g., to 50% so that charging is stopped
2. Start the Octopus Test Charge
3. increase the Charge Limit up in the car e.g., to 80% so that charging is no longer inhibited
The Octopus Test Charge completes Okay and the Car/Charger is activated.
It's definitely a game of hit & miss but I managed to get through the Test without having to lower/raise the car's capacity. I probably just caught it at the right time by sheer chance.
The good news (although confidence is not yet that high) is that Octopus charged it perfectly last night. I left the vehicle plugged-in, removed the schedule from the Charger (effectively making it dumb) and left the car with a 80% max setting on it. I set Octopus to reach 80% also, by 7am today. My Porsche App said that charging was Paused, but seemed to go through the Initialising -> Pause cycle a few times when I checked the app from time to time.
After a short while, Octopus created 2 charging sessions (one from 3am to 3:30; and one from 3:30am to 5am for some reason). I checked it at 2:30am and nothing had changed. When I awoke at 7:15am, it was all completed. Yes, I am an insomniac at present.
I will try and stick with the approach of letting Octopus control the charging now and see if my confidence increases over time.
I also tried the 'Bump Charge' option in the Octopus app yesterday afternoon for a short period and it seemed to work as designed also.
stevieg
Steve
100% the same as you but after a few nights I just trusted the process and it has never let me down... Until recently, but its an issue with my car. It won't now accept a charge faster than 3.6kw no matter what the AC charger power is. This is a car issue though as tested multiple AC chargers and it's only my car thats nobbled.
Booked in at the dealer to look at it, along with no assistance systems (all showing errors since the first cold night a week ago) and no speakers on the right of the cabin... Only got sound on the left side!
Also, note that as long as the Octopus app is driving the charger process and you have a ready time set of AFTER 5:30am, Octopus will continue to charge your car MUCH later than the cheap rate of electric... but still charge ONLY the 7p. But you must let the app schedule the charge.
niall
Niall
Manchester
Macan 4 Electric, 911 Targa 4S
This is a solution that has worked for me.
I had the same problems that are detailed in this thread in not being able to set it up, and couldn't get the test completed, even tried the options people have had success with but couldn't either hit the test at the right point, or it just doesn't work.
I've got a Macan 4 with Andersen A2 charger and this is what worked for me, but should work for any charger.
- Leave the cable disconnected
- Delete all schedules from the charger, and put it in unlocked mode. So the car will charge as soon as it's connected.
- Delete all the settings (destinations) from the Porsche App
- Create a new destination to stop the car charging as soon as it's connected. I did this to start in the future, but also set the optimized charging to be 23:30 to 05:30. This is the key step as it stops the car charging as soon as you connect it - and the Octopus Intelligent Go setup only works if the car isn't charging.
- Connect the cable to the car and check it's not charging in the Porsche or charger app (charger app seemed to show status more accurately for me)
- Then run through the Octopus Intelligent Go setup by adding the device and running the test.
- All been working well for me now.
One thing I noticed but would be nice if others confirmed is that even if you set the Octopus app to charge to 100%, it seems to only charge the car to the % set in the Porsche App. So I've changed the Porsche App to be 100% and will use the Octopus App to set 80%, but will only need to change in the Octopus App when we want a 100% charge.
Lastly, for me the destination that I'd setup in the app got deleted by the Octopus process, so I didn't need to delete it afterwards.
Hope this helps, as I wasted hours trying to get it work. I can't believe that anyone at Octopus actually tested this themselves before giving out those generic instructions that don't work.
Electric Macan EV Macan 4 EV - Octopus intelligent sync issue destination-settings
SimonEV
Simon
United Kingdom
Octopus Test "generic" instructions want the car to be ready to charge, but with the charging stopped at the beginning of the Test Cycle, but also without anything inhibiting charging during the test, which also contradicts the second requirement.
thealbs
Manchester, UK
Well, mine started playing up again last night ! I plugged the car in expecting Octopus to take control and it did nothing... and the car just started to take a charge at the higher rate, as I watched Octopus, charger and Porsche apps waiting for something to intervene and pause the charging. Nothing did ... until I did .
I unplugged the charger, tried several times to get it going and then eventually (after several rather lengthy charges that were not expected to happen) Octopus set its schedule of three short charging stints for the upcoming early hours. However, the car continued to take a charge as though Octopus had not intervened.
I suspect this may be related to broadly reported issues of connectivity to the Cars themselves on the Porsche network (see other threads re pre-conditioning not working) but that is only a guess... as most of the attempts at pattern-matching seem to be with diagnosing these issues when they arise.
I haven't had 2 consecutive charging evenings work without intervention so far, which is very frustrating.
Tonight I have decided to remove the Octopus control and see if the Porsche schedule will take control between 23:45 and 05:30 tomorrow... which should be at the cheaper Octopus rate.
I'll need several charging cycles without failures before confidence starts to return as these various combos of car, Octopus and charger do not seem to be as good bed-fellows as we might wish.
I hope others are having more success - and confidence - than me !
stevieg
Steve
yes… 100% the terrible car connectivity. Unless the car has registered its location at home in the Porsche app, and can be connected with, octopus can’t control it.
so many times I cannot send a pre conditioning request, check on charge status, remote lock/unlock etc as car cannot be reached. Yet it seems to often be fine on location, just not communication. No idea when or if that will ever be sorted.
Mike A
Mike
I have tried to connect my Macan 4 to Octpus Inteligent Go without success. I am giving up because even if it does by some accident manage to complete the test sequence I am not convinced it will be reliable. Not sure where the problem sits but a general observation Porsche understand the mechanical aspects of a car but are useless when it comes to software. A car had lost its sole and is no more than iPad with wheels.
thealbs
Manchester, UK
Yep - not sure where the issue lies either but I have reverted to letting the car schedule the charging at roughly the times when Octopus rates are lowest. I have disabled Octopus and Easee intelligence and just let the car draw the power between those times.
I have noticed that, if I say charge between 11:30pm and 5:30am and be preconditioned for 7am it is still charging between 5:30 and 7am (which seems wrong to me) but I have become very frustrated when trying to get Octopus and Porsche App to talk consistently.
