- First Name
- Steve
- Oct 27, 2024
- UK
- Macan EV Turbo, Lotus Emira, Lotus Elise S135
Have you found it to be reliable Steve? Its my first run of it tonight but had a few issues when I let the EV Charger schedule previously.
Any issues with the car coming up with a charging error when it is first plugged-in if Octopus doesn't permit it to draw charge?
Also, I am assuming this is all controlled by some central Octopus server-side cleverness once configured, and it doesn't rely on the App being active on your mobile?
Cheers
Ok so you need to make sure you have completed the test charge so the Octopus App knows when your car is at home and that it has control of the MyPorsche app. It will stop the charge by creating a departure schedule in the charging section of the Porsche App and thus making the car suspend the charge. Octopus then uses this to turn the charge on and off.
The thing to do is to plug the charger in when you are at home and leave it plugged in as much as you can. The car WILL start to charge initially, as your charger will be set to start charge straight away. Within 30 minutes, but normally less than 5, the Octopus App will suspend the charge and show you a schedule in the app. Just leave the car plugged in and by whatever time and SOC you have set in the Octopus app, the car will be done.
I always make sure my target charge % is the same in both the car/Porsche App and also Octopus.
App just needs to be on your phone and logged in I think (to get the notifications). You don't need to be actively 'in the app' for it to work.
See how it goes!
