- First Name
- Adrian
- Jan 11, 2021
- Aberdeen, Scotland
- 992.2, ex.Taycan GTS ST owner, Macan T (EV upgrade a tempter!)
Ok so there should be nothing for you to do.I haven't purchased a separate data pass. Its the one that came with the car which is having problems working. The Porsche app and the data pass account say it should all be connected and working but car says no
The car would have left the dealership with Porsche Connect active - this uses the same standard connectivity as Apple Music, Spotify, all online connectivity.
The data pass is intended for sharing an internet connection via the vehicle's wifi hotspot which is not what you should be doing as this is in addition to what you get with Porsche Connect. This is something you purchase from the Porsche Connect store and in UK is supplied by Vodafone.
If you want to connect your PCM to your phone's hotspot and use the phone's data service then you can do that also but again the question I have is "why do you need to do it in the first place?:.
Is your Porsche Connect service up and running - can you connect to your car remotely?
Have you linked your Porsche ID to either of Apple Music or Spotify (or indeed your own Apple Music account)?
If using Spotify are you using Spotify Premium (this is a requirement on the Taycan for example)?
