How useful is the heated windscreen option on a Macan EV?
I agree, does somebody know how to switch this on and off? That's incredible that it's impossible to find an answer to such basic question in the car's owner manual.
It in the manual and operates the same across other Porsche models.
Controlled with the Max button (P)
Electric Macan EV How useful is the heated windscreen option on a Macan EV? Screenshot_20241223_082308_Chrom
Electric Macan EV How useful is the heated windscreen option on a Macan EV? Screenshot_20241223_082325_Chrom
If you press the rear-windscreen demister button on the climate control, it clears mist on both windscreens.
I'm pretty sure that's how it works, as I did this a few times and it works.
This is not correct
iPadOnWheels
rob
netherlands
macan ev 4
Indeed, it only does the rear window and the mirrors, not the front windscreen.
sloubere
Stephane
Macan 4S IG
the heated windscreen uses electrical power as the heating power source.
the heated windscreen uses 250 kW of power - with the 100/95 kWh battery on the Macan you can run the heated windscreen for about 3 min before you hit 0% on the battery
it's a range killer no doubt…
just kidding - I couldn't resist!! :CWL: :rock: ;)
You mean 250 Wh? I can't believe this would use 250,000Watts...
gregb
2025 Macan EV 4S
One warning on the heated windshields.. once you see the wires, they can never be unseen. It's the reason I will never spec it. If you're neurotic, it can be a disaster.
Correct me if I am wrong, but I believe the heated windshield uses a silver coating inside the glass to transfer the heat. So the only visual occlusion is a tint effect that's caused by the silver.
Another forum user shared a picture of a heated windshield here if you want to take a look: https://www.macanevowners.com/forum...on-issues-fuse-box-location.17100/post-266428.
Oh well nevermind me. :)
I still have nightmares from the wired windshield in my Jag.
macanchan
Allan
If it's not the rear defrost and in fact the MAX windshield button, how is this draught-free?
I also read the front heated windshield only works when the ambient air temp is below a certain temp. I haven't had my car below 55F so I guess I cant test it.
rcomeau
Roch
Montreal, Canada
2019 Jaguar I-Pace
Which Jag if I may ask? I currently have an I-Pace and lurking here as I try to convince myself it is ok to essentially write off $50k worth of residual value that I will likely never recoup (all the recalls of my 2019 make it essentially unsellable) and tun around and drop another $150k CDN on another car that will have who knows what resale value (bit be really fun to own)...
My I-Pace has the wired windshield heater and while I really love it in the winters here in Montreal, I do hate the wires and the starry patters wheel driven at night.
