Tire pressure ideal vs actual
Coffinhunter
Donald
Odessa, FL
2025 Macan EV
The ideal tire pressure as shown on the door and owners manual is 46. However, in the display it shows current pressure at 46(ish) and there being a +7 deviation. Is there a way to change the ideal pressure in the computer?
Electric Macan EV Tire pressure ideal vs actual IMG_3144
srmacan
Macan 4, EQC, ID3
The PCM will show you the recommended tire pressure for your specific tyre size/type. Even when adjusted to this there will be minor deviation day to day.
Mine was delivered with +4 deviation and the ride was rock hard. Have since adjusted to the PCM recommended pressure and the ride is now much better.
Coffinhunter
Donald
Odessa, FL
2025 Macan EV
So, go by the computer not the book?
srmacan
Macan 4, EQC, ID3
Yes, the card on the door doesn’t take into account tyre size and type. Seems like a ballpark general recommendation.
tonyadduci
tony
chicago, il
porsche macan ev turbo
Is 46 the recommended pressure on a turbo for all 4 wheels?
tonyadduci
tony
chicago, il
very true, apologies... assume 285/45 in the rear and 235/55 in the front on 22"
tonyadduci
tony
chicago, il
all season. i know the sticker is on the door jam but I believe there are other optimal values...
tonyadduci
tony
chicago, il
so if there's no load, 1 driver 44 all the way around then, right?
wmras
Oregon
The ideal tire pressure as shown on the door and owner's manual is 46. However, in the display it shows current pressure at 46(ish) and there being a +7 deviation. Is there a way to change the ideal pressure in the computer?
The tire pressure on the door is at full load, regardless of the vehicle. It will always be too high for partial load and rarely correct for best handling (normally much lower).
In my experience with five new Porsche cars and SUVs, the computer display will be your best guidance and display absolute or differential pressure. I personally have learned to use the differential display and usually like every tire to be -1 psi. I then check the tire pressure with a racing gauge and adjust the tire pressure up or down by the display differential reading. My wife easily detects more than a 1 psi change! :CWL:
The computer display also changes with your load - especially useful in an SUV.
