Seat belt hook cover (no more hook slamming against pillar)
Good they work.
But I like Diego's better with Porsche & logo on it.
I am sure he will do well in this new business venture ?
BigApple
Andreas
NJ
Macan Turbo EV, E-tron, M3
Simple (and cheap - in every sense) system to eliminate seat belt hook ticking against the pillar. Easy to install and eventually to remove.
In my case it completely solved the problem, and I also installed it on the seat belts of the rear (side) seats
I bought it from this shop
Will these work ? (Amazon)
No porsche branding but available on Amazon
Zonie4S
Seth
Scottsdale, AZ
As I wait for my 4S (now at port in CA) and how to address this rattle, I decided look at my Alfa. Interestingly they use a felt piece on the back of the buckle. A simple piece of black felt that you can’t see given the buckle is black. A very clean look. The seat belts also have the sliding clip.
EdInSanDiego
San Diego
I tried one of the ones from Amazon but will be returning them. They were easy to put on, but the back side of them looks really sloppy, and that's the side you see and touch when buckling in. But possibly it can be fixed with double-sided tape or a touch of adhesive...
The ones from Amazon which I mentioned above did require stretching to get the seams to fit together and included small pieces of double-sided tape to keep them in place.
