Summer time - not updated automatically
Mr_Frenchy
Eric
Macan GTS 2017
Last night, Clocks were turned forward by one hour (Summer time) and today my Macan did not update its time automatically :( - I had to go to settings / date & time and modify the time manually (note the update date/time automatically option was ticked).
The car was connected to GSM, Wifi signals and to my phone via Android Auto and some how, it was not able to update itself ...
did someone else face the same issue ?
JonoNZ
Jonathan
Auckland, New Zealand
My Macan Turbo is the first car for many years that I have found does not correctly understand New Zealand summertime and adjust the time properly. I have had to change it to set manually.
nerv
Huy
BMW M3
My car has not updated since daylight savings change. It’s still 1 hour behind?
wuls123
macan EV
did someone else faced the same issue ?
Same here. If you switch off automatic, you will see there is no BST or daylight savings option for our American friends either.
so either the Porsche servers don’t have a proper time server or worse, it’s an omission from the PCM software…(I fear the latter, the former being an easier fix )
Switched to manual this morning, set the correct time. Then switched to auto now and it works as it should. Same happened in October.
wuls123
macan EV
Tried that - several times over the course of the morning - with no luck.
I switched to manual at 6:30 this morning and changed back to auto at 11:40 so maybe it has to stay a while in the manual setting (however it's not the right or intended use of the "auto" setting....)
ferrocinque
Francesco
Roma, Italy
Mine did it automatically, 5 minutes after I started the car this morning. Since it has been in my garage, I think that first it had to lock the GPS signal (from which I think it gets the correct time).
nerv
Huy
BMW M3
I’ll try this. I have it on manual right now. I’ll try automatic when I’m in my garage and give it a couple minutes.
QuiteBig
Steve
Macan electric 4S, BMW 440i, Mini Cooper electric, Fiat 500
Mine updated within seconds yesterday morning. I happened to notice because I had sent a route to the car, and I wondered why I was arriving an hour earlier than expected (it was only 8am, I was still half asleep), then it changed to an hour later almost immediately.
I was particularly sensitive to this exact point as my BMW never managed to update automatically despite it being ticked, and it used to annoy me more than it should do. A win for Porsche :)
CHpluto
Patrick
I had to change manually. Then switched to auto...and I had winter time again.
hal1965
I have another issue - I manually changed the time after the clocks changed to BST. The time on the instrument cluster display is one hour adrift from the time on the centre display. I have tried a reboot, re-setting the time but cannot get them to synchronise. Can be seen in this photo:
Electric Macan EV Summer time - not updated automatically SdC - 1
Does anyone have a fix?
Mine didn’t change automatically, despite being set for that. I then changed it manually. I got in this morning and set a destination and noticed it was reporting it was going to take me 1:10 to drive 4 miles. The dash clock and driving screen showed the correct time but the PCM was an hour out. I pulled over, turned off auto-change and then turned it back on and voila ! It then reported I would arrive in 10 mins.
