- Feb 18, 2025
- Earth
- Macan 4S, Audi RS5
Doesn't work 100% of all time or doesn't work 100% of the times when it is supposed to? Because there are lots of circumstances where the brake pedal won't use regenerative braking and will switch immediately to the hyrdaulic brakes. That's normal.For me and some others, the brake recuperation doesn’t work 100% of the time for some reason. Although maybe we are in the minority here.
Or do you mean lightly pressing the brake pedal only a little bit sometimes doesn't show regen?
The setting does not have any effect on brake pedal regeneration. The only way it could possibly make a difference is if the code for regen in general is crashing on your car and that setting restarts the service until the next crash.When that happens I get terrible consumption and need to switch thrust recuperation on.
Why turn it on uphill? There's no place to recover energy if you're actively powering the motor to climb a hill.In addition I live in an hilly area so generally speaking I coast when it’s downhill or even terrain and switch thrust recuperation on when going uphill.
You have it. It is the unlabeled button in the bottom right of the settings page when you tap the Car icon. If you are seeing energy recovery when coasting without braking, then it is turned on.Now for my car, I have not found any option to turn re-gen off or on. Is this an option that not in my car or on US models?
