Apple Announces Porsche Support For iPhone Car Keys
alvaro
Ɓlvaro
ATL, GA Metro - USA
Man, holding my breath on this. This is one of the 3 things I think this car is missing.
The other two being the built-in dash cam (my '26 BMW x6 has this) and the 22 kWh onboard charger.
alvaro
Ɓlvaro
ATL, GA Metro - USA
this is _NOT_ definitive - but it _IS_ indicative…
background: when you present a modern iPhone/iOS to a device that supports/enabled NFC the appleWallet will appear because the NFC wireless in the phone "wakes up" and launches the AppleWallet (or other NFC app)…
therefore a rudimentary test of "does this thing do NFC" is to present your phone to the potential NFC reader and see if it wakes up…
so I did the following test…
I presented my phone to my neighbors 2025 BMW X5 hybrid (which does support apple car key) - and my iPhone "woke up" and initiated NFC activities - but it did not unlock the BMW because, well my neighbor doesn't trust me with his car keys - go figure - :CWL:
I presented my phone to my 2024 Macan Turbo EV w/comfort access - my phone remained idle/offline/dark/asleep - it did not indicate or detect any NFC radio waves from the door handles of my 2024 Macan Turbo EV…
now I realize this is not definitive as a test - because Porsche may have the hardware present but disabled…
but for what it's worth my simplistic "NFC detector" does not trigger when presented to my 2024 Macan Turbo EV…
YMMV…we'll have to await more details from Porsche as to when/how this feature will be supported.
I welcome any factual data.
What do you mean by "presented" ? One of the slight anoying downsides is PAAK (at least on the BMW and same on a Rivian Im told) works from like up to 8 feet away. Even through walls. So anytime I walk past my garage or driveway it unlocks the BMW if Im wearing an Apple Watch or have a iPhone in my pocket.
Did you wave your phone at it or something? Also, most PAAK cars need to paired super closely, e.g. place your device in the inductive charging tray... So I'm curious on how/why your phone acted differently with the BMW.
I'm gonna grab one of my kids phones and see if I can replicate the behavior you observed. Ya know, for science.
TRP
Louisville KY
2021 Mach E Premium AWD
I have a 21 MME and use PAAK exclusively. That being said, if my phone is in my back pocket when I approach the car it can be hit or miss if it connects. Phone in hand is usually not an issue.
I am hoping for Apple CarKey to be available sometime later this year. However, it is unclear whether it is only going to be available for the newer 2026 models due to hardware requirements. I am not an expert, but it appears that it requires NFC +/- UWB (per AI search).
I asked AI: Do you need both NFC and UWB to use Apple CarKey?
No, you do not need both NFC and UWB to use Apple CarKey, but the experience varies depending on which technology is supported.
? Apple CarKey: Technology Breakdown
TechnologyRequired?What It Enables
NFC (Near Field Communication)Yes (minimum requirement)Tap your iPhone or Apple Watch near the car’s door handle to unlock/start the car
UWB (Ultra-Wideband)Optional (but recommended)Enables hands-free unlocking and enhanced spatial awareness (e.g., unlock just by walking up to the car with your iPhone in your pocket)
Here's a more detailed explanation:
  • NFC:
    Near Field Communication is a short-range wireless communication technology primarily used for data transfer and contactless payments. It operates at 13.56 MHz. NFC is used for short-range communication, typically within a few centimeters. For Apple Car Key, NFC is used for initial pairing of the iPhone or Apple Watch with the vehicle, and also for unlocking the car when the device is held near the door handle.
  • UWB:
    Ultra-Wideband provides more precise location tracking than NFC or Bluetooth. It allows the car to determine the user's exact distance and location, enabling features like passive entry (unlocking as you approach) and remote starting.
When looking at the Macan’s manual, UWB is listed as part of the radio equipment. But it is unclear whether NFC is available. However, I found the NFC frequency listed under wireless charging.
Radio equipment, frequency band, maximum transmission power:
WCH-304
Wireless charging
127.55 kHz
13.56 MHz
15 W
NFC operates at 13.56 MHz, while Qi wireless charging typically uses frequencies between 110 kHz and 205 kHz.
So it is possible that the NFC hardware is located in the charging compartment and that you will have to place your phone there for pairing and driving. Just my wishful thinking…
seabird
Earth
Macan 4S, Audi RS5
NFC is not required for CarKey. At all. It's available as a fallback implementation in the event that your phone battery has been dead for over 5 hours (the reserve time for BLE to continue to work after the phone shuts off).
There is no hardware missing from any EV Macan that would prohibit implementation of this feature when and if Porsche decides it wants to do so.
Dragon Tourniquet
Nevada
That may or may not be true, as one of the requirements COULD be that the transponders in the car be certified by Apple. This turned out to be the case for TouchPoint (the hotel / business lock equivalent to Home Key / Car Key), and is why Ubiquity had to release new hardware to add support for it. Since the docs for getting the Car Key entitlement from Apple in the MFi program are confidential and not available to the general public, we don't know if such a requirement is in them.
seabird
Earth
Macan 4S, Audi RS5
The UWB requirements have been posted since 2021. The hardware certification is not Apple's. It's Car Connectivity Consortium's Digital Key Release 3.0 or higher. This hardware is in the Macan. It is a published standard.
That's NFC, not UWB.
Station
CO, USA
My Tesla does this phone key thing specifically using it's UWB and it's amazing - and rock solid. If my $111k pending Macan 4s delivery doesn't have Ultra-Wideband I'll be stunned.
Dragon Tourniquet
Nevada
I understand that, however just because Apple uses a standard doesn't mean they don't tack on extra requirements (ex: they used to have MFi certification requirements for anything to connect via the USB ports on iPhones).
Well aware of that, but again, Apple has in the past tacked on extra requirements before they will allow iOS to use something, and in this case you have to sign a confidentiality agreement to get the API documentation and iOS entitlement allowing use of Car Key. That agreement is ONLY available to auto makers. We don't know what is in that agreement, which may or may not include extra hardware requirements. If you worked for one of the auto makers that signed the agreement and are sharing what is in it, thank you, but you are violating that NDA and could be subject to massive penalties / litigation.
seabird
Earth
Macan 4S, Audi RS5
Apple is a member of CCC, along with Porsche. The whole point of creating the CCC standard is to avoid this fracturing of hardware requirements.
I am not violating any NDA. Again, the CCC standard is published. You can get your hands on it yourself very easily and legally by becoming a member.
Dragon Tourniquet
Nevada
I am not violating any NDA. Again, the CCC standard is published. You can get your hands on it yourself very easily and legally.
The CCC standard is published. The MFi agreements and APIs for iOS are not. That is where any extras would come in (which Apple has done in the past with USB, even though they were part of the USB Implementers Forum). Without complying with Apple's requirements you can't get them to issue you an entitlement for your iOS app to allow it to use Car Key functionality.
seabird
Earth
Macan 4S, Audi RS5
MFi accessory certification does not have any special hardware requirements for CarKey. I am not sure what you're basing all this on, as there is no Apple-specific hardware requirement for CarKey beyond CCC compliance.
A random hypothetical that Apple "could" require something proprietary for CarKey is not only a claim without evidence, but would not in any way further adoption of Apple Wallet, which is of course their primary business objective.
The TouchPass hardware change was not an Apple-proprietary requirement. The MFi certification program is optional. For every random and irrelevant example you have here, there are countless others that Apple participates fully in, from FireWire to DisplayPort, to USB-C.
There is no special Apple hardware in any of the CarKey-enabled cars. If you think differently, feel free to provide your evidence.
Dragon Tourniquet
Nevada
My point is we DO NOT KNOW what Apple requires. You can state there aren't extra requirements (such as specific models of NFC or UWB hardware, or paying Apple a fee per vehicle as part of the MFi program, similar to TouchPass or Home Key), but without access to the agreements to get the entitlement for the iOS app, we have no way to know.
Apple did open up some of the API documentation for CarKey here (specifically how to program to it, but not what the requirements are to get the entitlement): https://developer.apple.com/documentation/CarKey.
Using CarKey requires the com.apple.developer.carkey.session entitlement. To get that entitlement, you need to get MFi certification. Who needs to join the MFi program? https://mfi.apple.com/en/how-it-works.html
Here's some info on using keys in Wallet (including Car Key): https://learn.wallet.apple/keys
Requirements for the Apple Wallet Access program (more focused on NFC, but I haven't been able to find UWB specific info even though they also support UWB door locks for Home Key): https://register.apple.com/resources/docs/apple-pay/access/program-guide/requirements/
It will have UWB, it helps to secure the car / key signal against being hijacked by signal relays, so is a security measure. In the UK, as ā€˜prestige manufacturers’ adopted it (particularly Range Rover) it was so successful the thieves switched to using the Can Bus hijack instead.
