Tailgate Only Opens Halfway – Memory Not Working Reliably
ferrocinque
Francesco
Roma, Italy
Hi everyone,
I’m having an issue with the tailgate on my Macan 4.
I’ve set a custom opening height by manually adjusting the tailgate and pressing the close button until I hear the confirmation beep – so the memory function seems to activate correctly.
However, most of the time, when I open the tailgate, it only goes up halfway, well below the saved height.
Occasionally, it does open to the correct memorized position, but that’s rare.
It’s quite frustrating, as I have to manually push it up almost every time.
Has anyone else experienced this inconsistent behavior? Could it be a software bug, a sensor issue, or maybe something temperature-related?
Any thoughts or suggestions would be greatly appreciated.
Thanks in advance!
Did you try calibrating the door to a full open position? Try that to see if it holds reliably. If it does then incremently set for a small lower height and so forth. It might be that your trying to set it to low. I did mine to about 3 inches lower than full height to clear the garage door strike distance and it always works but I do recall trying to do it lower and it did not stick or acted erratically
ferrocinque
ferrocinque
Francesco
Roma, Italy
I tried as you suggested, but no matter what position I save it in, when I reopen the tailgate it always opens significantly lower than how I saved it.
It’s really annoying, as I take my dog with me every day and every time I have to force the tailgate open
RunningOnSolar
Scott
Ohio
Macan 4, Subaru Solterra
I had multiple intermittent issues with my tailgate that required dealer attention. There is a fix for tailgate issues and mine is working reliably now, but it required a new part and recalibration to get there for me.
i haven't had this issue...every time i set the height, it opens at that height properly from then on.
ferrocinque
ferrocinque
Francesco
Roma, Italy
Thank you. But wasn’t it not working from the beginning? Mine was working perfectly until just a few days ago (I have the car since November).
RunningOnSolar
Scott
Ohio
Yes. When I took delivery there was no issue. It worsened over time.
It is worth checking with your dealer. I know how annoying it can get. I eventually had both and opening and closing issue.
