- First Name
- Sergey
- Dec 19, 2021
- Indianapolis
- 20 Cayenne Turbo, 23 Taycan Turbo, 24 Macan GTS
I would like to share headlights specs, as some @Fleming23 mentioned the brightness and absence of dynamic cornering feature. Ideally, we need to measure the brightness, and I would be up to it if someone can recommend what can be used to do so as I have MY24 Macan GTS if someone else can measure Macan EV LED and LED Matrix beams.
Dealer's internal docs provide the following regarding Macan EV Headlights in the US.
I found this to be inconsistent from usual Porsche headlight setup:
High Beam Assistant is the + in PDLS+ option on other models. Standard on Macan EV.
Dynamic Cornering Light function is part PDLS option on other models. Not offered on Macan EV.
LED type has no PDLS designation. LED Matrix Design has PDLS+ designation.
LED
- Includes High Beam Assistant
- Upper: 4-point LED Daylight Running Lights with Indicators in LED fiber-optic technology
- Lower: Low/High Beam, and Auxiliary High Beam with speed-based driving light control and dynamic headlight leveling
LED Matrix Design PDLS+
- Includes Static Cornering Light
- Upper: 4-point LED Daylight Running Lights with strongly contoured three-dimensional light signature and Indicators with strongly emphasized LED strips
- Lower: Low Beam, High-power Auxiliary High Beam, and Matrix Design Lense
- US has no Matrix functionality
- No mention of speed-based driving light control or dynamic headlight leveling but probably assumed
- Features Coming/Leaving Home animation
- Optional in Black or Glacier Blue
Compare this to Macan ICE LED Headlights with PDLS+
LED
