Range in Macan Turbo
craigydean
Craig
Macan
I bought a macan turbo in early September and had a dash fault after two weeks that read Drive System Control Fault.
I was told by sales guy I bought the vehicle from it was a software update!
Two weeks later with this fault making an appearance two or three times, i was travelling from London to Scotland on a trip of 428 miles.
I had to charge the car 3 times.
The car has been at Porsche dealership now for a month and still the 100% charge shows only 244 miles.
I have done 1700 miles so far and Porsche have done over 300 miles while trying to empty and recharge / reset modules etc. What range is actually fact with these turbos as it’s nowhere near 300 on days Shen it’s 15degrees never mind 3 degrees.
the amount of energy my car is using is incredible.
Incidentally, another dealership told me my car had a catastrophic fault when I was there dealership for my third charge on my return journey.
Craig.
Electric Macan EV Range in Macan Turbo IMG_5502
Electric Macan EV Range in Macan Turbo IMG_5389
Electric Macan EV Range in Macan Turbo IMG_5420
racerjim
Jim
Canonsburg, PA
2024 Mercedes Benz GLC300
Your car is using more than mine. I took it for our first long trip in cold weather. Got 185 miles going from 100% SOC to 20%. Was about 41 kWh/100 miles compared to your 50. Outdoor temp was ~20F/-4C. Right now the car is at 79%/207 miles.
craigydean
craigydean
Craig
Macan
Thanks Jim. Trying to understand what is the actual achievable mileage is with a turbo?
cheers Craig.
Reactions: MMR
MaccyT
Maarten
Netherlands
Macan Turbo / Audi Q3 TFSIe
Mine is at +-230 miles (352km) at 80% charge and around 6 degrees celsius outside.
Average consumption on long (easy right foot trip with these temperatures) is around 34kWh/100miles or 21.3kWh/100km in my case.
I Bet I can do around 30kWh/100miles in the summer period but only got the car for 3 weeks.
(22” RS Spyder wheels)
MMR
cheers Craig.
I’ve had my Turbo for a few days now, and would be interested in knowing the answer too….what am i likely to expect in the UK winter for both urban and motorway driving
100% charge, driving 55 mph (90 kmph) in reasonable temperature, on 20 inch wheels, I can probably do >320 imperial miles in the Turbo. (I haven't done this at the full length, but this is what the math says.)
Cold weather, 75+ mph, hilly terrain, not wanting to stay at 100% charge ... 250 miles, maybe.
MMR
Appreciate that. So moving from 20” to 22” wheels would roughly knock 5–10% off those figures I’d imagine
Craig.
A couple of things to consider:
Size of rims and tyres fitted? 20" aero are best for range and 22" worst.
Data provided shows a high consumption but given your average speed (64 moh) that should not be surprising.
Set your units to miles/kwh to save some math and then share your Total Trip details from the app as this will provide a better data set than a single trip in isolation.
Motorway driving is typically the worst for range as the opportunity to recoup energy is less.
Sportier drive modes will consume more energy.
The range estimate is just that an estimate which takes historical usage data into consideration- driving style, journeys etc.
Chemistry of the battery is better than original Taycans (J1.1) and so winter driving will be less impactful on range.
Short trips lead to high consumption.
Rely on consumption data rather than the guessometer readout.
Ignore WLTP range estimates as these are lab based and not indicative of real world driving. A differential of up to 30% would not be surprising.
My 4S at reasonably mild weather is reporting a total range of 320 miles
Electric Macan EV Range in Macan Turbo 1765541140311-
RGBArgee
Rick
Somerset and Brittany
Not sure tyres/wheels make that much difference as rolling radius is similar whatever size isn’t it . Just more drag from wider tyres associated with bigger wheels.
MaccyT
Maarten
Netherlands
In my previous E-tron the car configurator showed a similar difference especially when moving away from the “aero” rims to proper sportier ones.
RGBArgee
Rick
I can understand better aerodynamics from aero rims. My old Taycan had 21 in Cross Turismo rims and was less economical than 19in standard flatter surface rims.
I have a turbo on 20 inch wheels, in summer 500km in winter 400 …
Mix driving of 125km/h highway and 70 / 80 on backroads
Fluff
Wheel size is well known to make a difference, 20 to 22 inch knocks 20 miles off the range. Everything adds up, roof rails, rear wiper, all add drag, all with the same battery, means less range in any given situation.
That said the OP managed an average of 64mph, thats quite impressive in the UK, where the legal max is 70mph, so i'd expect maybe 220miles range, at that sort of speed.
Wheels (rims) make a huge difference - RS Spyders are probably the worst as they are quite open. Aero wheels by contrast are more efficient. 20" will give the optimum range for a given model.
WLTP is around 3.2 mi / kwh giving a theoretical max of around 304 miles but as we all know that's tosh and so 260 ish is more realistic.
Need more data (as always) to get a better indication of range than rely on a single motorway sprint!
