Successful Plug and Charge at new Tesla station
de0xyrib0se
Sofia, Bulgaria
We have it easy in the EU, most Tesla chargers (that I have seen) are CCS2. Just pull up and charge. The part that sucks is their congestion fees; oftentimes you have to drop everything and "Run, Forest, run!" once you hit 80%.
dwauch
Santa Monica CA
2025 Macan EV
Today, I used my new adapter for the first time and had a successful charging session in Durango, CO at a new Tesla station. I even used “plug and charge” successfully which I have never been able to use at EA. Very happy!
Cool. Good to hear. What did you have to do to make plug and charge happen? Did you download the Tesla App and create an account with a credit card on file? Or did you have to do anything with the porsche app to tee it up for plug and charge. Plug and charge is such a game changer for me. fyi - I used plug and charge all the time on EA. Both in my hometown and on the road. It's very reliable.
Porsche Charging Service (PCS) is all you need for plug&charge to work at North American Tesla Superchargers … PCS is setup via myPorsche app for your vehicle - you can have a Tesla app setup as well but it's only for backup purposes as an alternative method for starting a charging session should myPorsche app for some reason not start a charging session…
NOTE: if plug&charge is not working you then have the option of using the Porsche app or the Tesla app to start the charging sessions - having done this process with both app's I will suggest the Tesla app is fewer steps and a little more straight forward - but only if you already have it setup with your account & billing information…but once plug&charge is not working and your going down the path of app based activation it's 6 of 1 half dozen the other as to which app you're using to start the session…
these are the methods for starting a charging session in North America at Tesla Superchargers
  • myPorsche app - plug&charge - requires billing w/Porsche charging service
  • myPorsche app - taping "start charge" in app - requires billing w/Porsche charging service
  • Tesla app - use the Tesla app to start a charging session w/Tesla account + billing information
  • tap to pay using credit card payment @ the supercharger stall via the small LCD screen on the charging stall - V4 Tesla supercharger's _ONLY_ - V3 superchargers have no Point-of-Sale screen
plug & charge should work 99% of the time - the other 3 methods are alternatives should plug&charge not work - all the app based and plug&charge methods require you have an account and billing information already configured in the associated application…
dwauch
Santa Monica CA
2025 Macan EV
Helpful thanks. Sounds like if I have plug and charge set up for EA, with a PCS account set up, I might just be able to pull up to Tesla and start charging. Will give it a swing! There is one in my neighborhood. That would be great. I generally do not plan to use TSLA but good to have as a backup. Thanks.
yes if plug&charge works at EA it's very very likely it will also "just work" at appropriate Tesla Superchargers … not that the two networks use the same technology but rather than Porsche already knowns how to bill you!!! LOL
not _ALL_ North American Tesla Superchargers allow non-Tesla's to charge at them - they must be V3/V4 stations - the rule of thumb is if the station's location is listed in the myPorsche app (charging map) or in the PCM Navigation it's 99% certain to function for non-Tesla's…
if your local Tesla Supercharger is NOT shown to you in the PCM navigation it's likely an Urban/V2 Supercharger which do not support non-Tesla's (of any kind regardless of vehicle vendor - urban/V2 stations are Tesla _ONLY_)…
why the "hedge" on 99% certain - data error in the database that may or may not be present…
there are approximately 35,000 Tesla Supercharger stalls in North America
25,000 of them are V3/V4 superchargers that support non-Tesla's charging there - the remain 10,000 stalls are Tesla ONLY and are typically Urban (72 kW max) and V2 superchargers…
over 90% of new Tesla sites not yet built are planned to be V3 or V4 superchargers - so the growth is inclusive for all EV's…but there are some existing supercharger sites that will only support non-Tesla's if Tesla chooses to update them to newer hardware in the future.
there are a few (10 or less?) V4 sites that happen to be Tesla only…I don't know what criteria Tesla uses to make a V4 site Tesla only - but they do exist - one site I'd love to try out is local to my area - and supposedly supports 800V charging - which means a Macan would not be limited to the 150 kW or less if allowed to charge there - but these sites are "test" sites so Tesla is restricting their use…
the best source for what Tesla Supercharger's are open to you as a Porsche victim/customer is the myPorsche app charging map or the PCM navigation map with charger's being shown…if a Tesla site is listed on either of those two maps it's likely you'll be able to charge there with no issue.
my $0.02 YMMV
Not much luck charging Taycan at Tesla as I did a test as I prepare to welcome Macan EV this summer. Have Porsche branded Adapter.
Both selectable from PCM and App and PlugShare shows that they support non-Tesla vehicles.
Station 1: Plug-n-Charge did not work after many minutes of the initialization but able to start charge from Tesla App with really nice peak speed of 119kW when at 60% SoC and nicely preheated.
then went to
Station 2: Plug-n-Charge did not work after many minutes of the initialization and not able to start charge from Tesla App even after trying several stalls.
realfan
Albert
2026 BMW i5
I'm glad I found this thread. I am a new 2025 Macan 4S owner and I will unlikely ever need to charge locally given the range of this vehicle. However, I would like to make some longer driving trips so I bought the Porsche NACS adaptor specifically to be able to use Tesla's network. That said, in the "Charging Service" section of the My Porsche app (Android phone), it says that my account is active for the ChargePoint network. It also says directly above that my "Charging Service is valid. Ready for charging." I did input my credit card, etc.
What I can't tell is whether or not I need to do anything else to be able to use EA or Tesla stations? It only shows ChargePoint as active. I plan to experiment at some point at a nearby Tesla charging station to see how this works.
I have also downloaded the Telsa app and created a new account with my CC as a back up. If anyone has any other pointers, suggestions, advice, please let me know. Thanks in advance.
realfan
Albert
2026 BMW i5
Replying to my own question after more research. I think Chargepoint includes all Tesla chargers so I should be good to go using the Porsche charging app. I will give that a try and use the Tesla app as a back up.
atebit
PA
Macan 4, Macan 4S
When your dealer picks out punched the car and enrolled it in MyPorsche, you should’ve received a bunch of emails, one of them was to go into the Porsche app and set up the Porsche Charging Service. If you e don’t that, you’re all set.
Also, Never Mind the Tesla SCs, Here’s the One Year of Free 30 Minute EA Charging Sessions.
realfan
Albert
2026 BMW i5
I did not get any info on the one year free of 30 minute EA charging sessions. I wonder if that's because I bought a used 4S that was put into service in March 2025?
correct - Also since about 2025 Porsche no longer offers 1 year included/free EA 30 minute sessions in North America - this is no longer a thing.
MKSZ51
Mark
Iowa
2025 Macan 4, 2025 Silverado 1500 ZR2, 2026 911 Targa 4S
One other comment - you can only "forget" about Tesla Superchargers if you have abundant Electrify America chargers close to you. In the Midwest we don't - but the Tesla Supercharger network is built out well. We did an 800 mile weekend trip in the last couple of days - we used Tesla Superchargers exclusively. With plug/charge and the adapter it's a seamless activity.
realfan
Albert
2026 BMW i5
Thanks. I'm in IL one state over from you and agree that the EA network, although sufficient in and around the largest cities, doesn't work for longer trips. That's why I'm interested in how the Tesla system works. I have my Porsche adaptor now and I'm all good with being registered in the My Porsche app (ChargePoint network activated). I'm looking forward to a long weekend drive to test out the Supercharger capability.
MKSZ51
Mark
Iowa
I think you'll be pleased with how it works. Our 2025 Macan 4 came from Porsche Exchange - that is quite the dealership with a large inventory.
